大家好,
我正在将设计从STM8S105转移到STM8S207。 我正在考虑将时钟速度从最初的16MHz提高到24MHz,以便从核心获得更多的MIPS。 但是,对于时钟而言> 16 MHz,闪存需要1次等待。我想这些指令是由内核从闪存内取出的(即没有缓存)。 如果上述情况属实,则使用24 Mhz时钟核心运行速度会变慢。更快的时钟的唯一好处是更快的外设。 那是对的吗? (嗯,现在我想我应该用范围测试) 谢谢 尼科 以上来自于谷歌翻译 以下为原文 Hi all, I'm moving a design from STM8S105 to STM8S207. I'm thinking of raising the clock speed from originally 16MHz to 24 MHz in order to get more MIPS from the core. However, for clocks > 16 MHz, the flash memory requires 1 waitsate. I suppose that the instructions are fetched by the core from within the flash (i.e. there's no cache). If the above is true, then the core would run slower with the 24 Mhz clock. The only benefit of a faster clock would be faster peripherals. Is that correct? (Hm now I'm thinking that I should test that with a scope) Thanks Nico |
感谢EtaPhi的解释。我确实忽略了32位内存提取。我会在某些时候做一些测量,因为它似乎不容易预测。
干杯 尼科 以上来自于谷歌翻译 以下为原文 Thanks EtaPhi for your explanation. I had indeed overlooked the 32-bit memory fetch. I'll do some measurements at some point because it doesn't seem easily predictable. Cheers Nico |
2772 浏览 1 评论
3250 浏览 1 评论
1821 浏览 1 评论
3665 浏览 6 评论
6058 浏览 21 评论
1346浏览 4评论
210浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
460浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
286浏览 2评论
GMT+8, 2025-1-6 19:12 , Processed in 1.000876 second(s), Total 78, Slave 62 queries .
