男,
如果您询问哪些Xilinx产品具有伏特和/或非易失性存储器,则该信息在数据表中。 通常,所有FPGA产品都是非易失性的,但Spartan 3AN除外,它采用堆叠式闪存器件封装。 所有CPLD器件都集成了闪存(非易失性)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 m, If you are asking which Xilinx products have voltaile, and/or non-volatile memory, that information is in the data sheets. Generally, all FPGA products are non-volatile, except the Spartan 3AN, which has a stacked flash device in package. All CPLD devices have integrated flash memory (non-volatile). Austin Lesea Principal Engineer Xilinx San Jose |
更正奥斯汀的打字错误......
是: 通常,所有FPGA产品都是非易失性的,但Spartan 3AN除外,它采用堆叠式闪存器件封装。 更正: 通常,除Spartan 3AN外,所有FPGA产品都是易失性的,Spartan 3AN采用堆叠闪存器件封装。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索william hill官网 (并搜索网页)以寻找类似的主题。 不要在多个william hill官网 上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付william hill官网 帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Correction for Austin's typing error... Was: Generally, all FPGA products are non-volatile, except the Spartan 3AN, which has a stacked flash device in package. Corrected: Generally, all FPGA products are volatile, except the Spartan 3AN, which has a stacked flash device in package. -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
谢谢....
Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 thanks.... Austin Lesea Principal Engineer Xilinx San Jose |
联系您的FAE,他们可以为您提供电缆的挥发声明。
我不确定我们是否已接通FPGA,但如果我们这样做,则会说上电后没有信息保留。 奥斯汀,这是安全地点的一个非常具体的要求。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Contact your FAE and they can get you the statement of volatilty for the cable. I'm not sure that we have on for the FPGA, but if we do it will say that no information is retained after power on. Austin, This is a very specific requirement for secure locations. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
但有一个例外是模内效应。
对? 以上来自于谷歌翻译 以下为原文 One exception would be the on-die efuse though. Right? |
是,
如果您编写任何efuse,则由您来保护该信息。 我们在工厂编程的efuses代表了记录(和未记录)的功能,这些功能支持保证和发货的功能。 没有办法让你的一个秘密被Xilinx先验编程为efuse。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Yes, If you program any efuse, then it is up to you to protect that information. The efuses we program at the factory represent the documented (and undocumented) features that support the functionality as guaranteed and shipped. No possible way for one of your secrets to have been a priori programmed by Xilinx into an efuse. Austin Lesea Principal Engineer Xilinx San Jose |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2474 浏览 15 评论
1472浏览 1评论
601浏览 1评论
467浏览 1评论
2018浏览 0评论
741浏览 0评论
GMT+8, 2025-1-1 21:16 , Processed in 1.458581 second(s), Total 88, Slave 72 queries .
