我想了解PNA上的插值纠错,包括旧的(8720D / 8753E)和新的(N5241A / N5242A)。
* _Q1 - 什么是插值算法?_ *插值是否在校准点之间使用简单的直线插值? 插值是否通过(1)其他误差校正数据点之间的直线插值,或(2)通过校准点和原始数据点的直线插值,然后应用插值校准来插入误差校正数据点。 内插数据? 或者插值更复杂? * _Q2 - 插值精度_ *安捷伦非常谨慎地指出,当您设置INTERP(IEC)时,不能保证纠错的准确性。 但是......没有任何东西可以告诉你降级有多糟糕。 我从手册中了解到,(a)当你插入的校准中每1 GHz有67个(实际)校准点时,IEC是“最准确的”; 并且(b)如果相移大于每5个数据点180度,则插值不起作用。 是否有任何(合理的)指南可用于使插值成为有用的特征? _ * Q3 - 在HOLD模式和插值中更改“激励”参数* _当您处于HOLD状态(无触发,无新扫描)时,可以更改启动频率,停止频率和点数,如果IEC /插值,它可以工作 是开。 这看起来很奇怪,因为参数被认为是影响扫描执行方式的“刺激”参数,而不是后处理。 但这是有道理的 - 当处于HOLD状态时,可以通过插值来改变这些参数(通过明显限制,即启动/停止频率必须是实际扫描的子集)。 因为插值不能提高数据的准确性(插值时不收集更多数据)插值测量的精度与非插值测量相同*如果*省略纠错精度(校准插值引入的误差) ? 在我看来,插值时唯一的精度降低来源是非插值扫描线中的校准点与数据点处于完全相同的频率 - 而不是(必然)插值时... _ * Q4 - 是否有解决这些问题的文件? 安捷伦或第三方?* _提前致谢!!! 以上来自于谷歌翻译 以下为原文 I would like to gain an understanding of interpolated error correction on the PNAs, both old (8720D/8753E) and new (N5241A/N5242A). *_Q1 - What is the interpolation algorithm?_* Does the interpolation use simple straight-line interpolation between calibration points? Does the interpolation interpolate error corrected data points by (1) straight-line interpolation between other error-corrected data points, or (2) by straight-line interpolation of calibratioin points and raw data points, and then applicaiton of the interpolated cal to the interpolated data? Or is the interpolation more complicated? *_Q2 - Interpolation Accuracy_* Agilent has been VERY careful to state only that when you set INTERP (IEC) on the accuracy of the error correction is not guaranteed. But... there is NOTHING that tells you how badly it is degraded. I know from the manuals that (a) IEC is 'most accurate' when there are 67 (real) calibration points per 1 GHz in the calibration you are interpolating from; and that (b) interpolation doesn't work if the phase shift is more than 180 degrees per 5 data points. Are there any (reasonable) guidelines that can be used to make interpolation a useful feature? _*Q3 - Changing "stimulus" parameters in HOLD mode and Interpolation*_ The start freq, stop freq, and number of points can be changed when you are in HOLD (no trigger, no new sweeps) and it works if IEC/interpolation is ON. This seems weird since the parameters are supposedly "stimulus" parameters that affect how a sweep is performed, not postprocessing. But it makes sense - when in HOLD, changing those parameters can be done (subsject to the obvious limitatiion that the start/stop freqs must be a subset of the actual sweep) via interpolation. Since interpolation cannot improve the accuracy of your data (you don't collect more data when interpolating) is the accuracy of an interpolated measurement the same as a non-interpolated measurement *if* you omit error correction accuracy (error introduced by cal interpolation)? It seems to me that the ONLY source of accuracy degradation when interpolating is the fact that the calibration points in a non-interpolated sweep line are at the exact same frequencies as the data points - and not (necessarily) when interpolating... _*Q4 - Is there any documentation that addresses these issues? Agilent or 3rd party?*_ Thanks in advance!!! |
> {quote:title = TheGris写道:} {quote}>我想了解PNA上的插值纠错,包括旧的(8720D / 8753E)和新的(N5241A / N5242A)。
>> * _Q1 - 什么是插值算法?_ * >>>或者插值更复杂? 相当复杂一点。 我们称之为圆弧插值,它实质上是矢量空间中的插值。 确切的算法是专有的。 我在本书的第3章中提供了更多的细节和几个例子(我知道,老话说,但信息确实存在):http://www.wiley.com/WileyCDA/WileyTitle/productCd- 1119979552.html >> * _Q2 - Interpolation Accuracy_ *>安捷伦非常谨慎地说明,当您设置INTERP(IEC)时,不能保证纠错的准确性。 但是......没有任何东西可以告诉你降级有多糟糕。 >我从手册中了解到,(a)当您插入的校准中每1 GHz有67个(实际)校准点时,IEC是“最准确的”; 并且(b)如果相移大于每5个数据点180度,则插值不起作用。 >>是否有任何(合理的)指南可用于使插值成为有用的功能? 如果每米测试端口电缆每5 MHz有1个点,则通常会满足VNA的指定性能(因此,如果您有两个1米的测试端口电缆,则每2.5 MHz需要一个点)。 >> _ * Q3 - 在HOLD模式和插值中更改“刺激”参数* _ >>当您处于HOLD状态(无触发,无新扫描)时,可以更改启动频率,停止频率和点数,并且它可以正常工作 如果IEC /插值为ON。 接受更改,但数据保留旧值。 较新的分析仪甚至不会更新刺激设置,直到获得新的扫描。 插值对测量数据没有影响,它只影响误差项。 您没有插入数据,而是在新的频率范围和点数上插入误差项,然后在更新显示之前必须获取新的原始数据(通过扫描)。 >>在我看来,插值时唯一的精度降低来源是非插值扫描线中的校准点与数据点处于完全相同的频率 - 而不是(必然)插值时...... >> _ * Q4 - 是否有解决这些问题的文件? 安捷伦或第三方?* _>为什么是,如上面的链接所示。 >提前致谢!!! 回想起来,非常欢迎你。 以上来自于谷歌翻译 以下为原文 > {quote:title=TheGris wrote:}{quote} > I would like to gain an understanding of interpolated error correction on the PNAs, both old (8720D/8753E) and new (N5241A/N5242A). > > *_Q1 - What is the interpolation algorithm?_* > > Or is the interpolation more complicated? Quite a bit more complicated. We call it circular interpolation which is essentially an interoplation in vector space. The exact algorithms are proprietary. I give quite a few more details and several examples in Chapter 3 of my book (I know, getting old saying that, but the info really is all there): http://www.wiley.com/WileyCDA/WileyTitle/productCd-1119979552.html > > *_Q2 - Interpolation Accuracy_* > Agilent has been VERY careful to state only that when you set INTERP (IEC) on the accuracy of the error correction is not guaranteed. But... there is NOTHING that tells you how badly it is degraded. > I know from the manuals that (a) IEC is 'most accurate' when there are 67 (real) calibration points per 1 GHz in the calibration you are interpolating from; and that (b) interpolation doesn't work if the phase shift is more than 180 degrees per 5 data points. > > Are there any (reasonable) guidelines that can be used to make interpolation a useful feature? If you have 1 point every 5 MHz for each meter of test port cable, you will typically meet the specified perfomance of the VNA (so if you have two, 1 meter test port cables, you will need a point every 2.5 MHz). > > _*Q3 - Changing "stimulus" parameters in HOLD mode and Interpolation*_ > > The start freq, stop freq, and number of points can be changed when you are in HOLD (no trigger, no new sweeps) and it works if IEC/interpolation is ON. The changes are accepted, but the data is held with the old values. Newer analyzers don't even update the stimulus settings until a new sweep is acquired. Interpolation has NO effect on measured data, it only effects the error terms. You are not interpolating the data, you are interpolating the error terms over the new frequency range and number of points, and then new raw data must be acquired (through a sweep) before the display is updated. > > It seems to me that the ONLY source of accuracy degradation when interpolating is the fact that the calibration points in a non-interpolated sweep line are at the exact same frequencies as the data points - and not (necessarily) when interpolating... > > _*Q4 - Is there any documentation that addresses these issues? Agilent or 3rd party?*_ > Why yes, as noted in the link above. > Thanks in advance!!! You are most welcome, in retrospect. |
1335 浏览 0 评论
2397 浏览 1 评论
2218 浏览 1 评论
2086 浏览 5 评论
2976 浏览 3 评论
1244浏览 1评论
785浏览 0评论
1036浏览 0评论
1335浏览 0评论
GMT+8, 2025-1-14 12:05 , Processed in 1.242895 second(s), Total 78, Slave 62 queries .
