我想知道外部显示器与16700B逻辑分析仪兼容的技术标准是什么。
是否有任何外部TFT监视器与16700B兼容,相反,是否有任何与此LA不兼容的CRT监视器? 我正在测试这样的LA,它不会显示任何带有TFT显示器的图像,尽管看起来系统在启动时和关机时都会处理某些事情。编辑:2012年11月4日下午5:05 以上来自于谷歌翻译 以下为原文 I am wondering what is the technical criteria for an external monitor to be compatible with the 16700B logical analyzer. Is there any external TFT monitor compatible with the 16700B and conversely are there any CRT monitors that are NOT compatible with this LA? I am testing such an LA that doesn't display any image with a TFT monitor although it seems the system is crunching something both at boot and at shutdown times. Edited by: latech on Nov 4, 2012 5:05 PM |
7个回答
16700和它所围绕的HP-UX系统支持许多不同的监视器类型,但与PC不同,它们无法识别监视器并动态调整设置。
有一种方法可以让16700循环浏览所有支持的监视器类型。 以下是安装手册: - 打开显示器 - 打开16700 - 立即按“TAB”键,每秒按一次约30秒。 - 当您看到一个好的显示器时,按“ENTER”键和“Y”确认。 您的显示器可能有多种支持的配置,分辨率不同。 如果您等待足够长的时间,它将循环完成所有配置并重新开始。 IIRC,它在大约25种不同的设置中花费2-3秒。 它们的刷新率从640x480到1280x1024不等。 如果显示器不喜欢像这样被推,并且无法快速同步,您可能永远看不到好的显示器。 一旦你有一个工作显示器,有一种方法,通过在加电时打入'BIOS',获得支持的分辨率/刷新组合列表,然后选择一个使用数字。 不幸的是,我已经忘记了它是什么,并且最近(在8月底)回收了我最近的HP-UX系统。 人 以上来自于谷歌翻译 以下为原文 The 16700, and the HP-UX system that it was built around, support many different monitor types, but unlike a PC, they don't have any way to identify the monitor and adjust settings on the fly. There is a way to get the 16700 to cycle through all supported monitor types. The following is from the Installation manual: - Turn on the monitor - Turn on the 16700 - Immediately press the 'TAB' key, and press it once per second for about 30 seconds. - When you see a good display, press the 'ENTER' key and 'Y' to confirm. There may be multiple supported configurations, at different resolutions, with your monitor. If you wait long enough, it will cycle through all configurations and start again. IIRC, it spends 2-3 seconds at each of about 25 different settings. They range from 640x480 to 1280x1024, at different refresh rates. If the monitor doesn't like being pushed around like this, and can't synchronize fast enough, you may never see a good display. Once you have a working display, there is a way, by breaking into the 'BIOS' at power-up, to get a list of supported resolution/refresh combinations, then choose one using a number. Unfortunately, I've forgotten what that is, and recently (at the end of August) recycled my last HP-UX systems. Al |
nvywyerwer 发表于 2019-5-15 13:38 谢谢,程序没有用。 在评估任何显示器问题或系统视频适配器问题之前,我预计可能还存在键盘不兼容问题。 以上来自于谷歌翻译 以下为原文 Thank you, the procedure didn't work. I am expecting there may also be a keyboard incompatibility before I could evaluate any monitor issue or a system video adapter problem. |
你需要一个带有PS / 2连接器的普通香草键盘。 带适配器的USB键盘可能无法正常工作。 越老越好。 人 以上来自于谷歌翻译 以下为原文 You need a plain-vanilla keyboard with a PS/2 connector. A USB keyboard with an adapter probably won't work. The older the better. Al |
我试过两个香草PS / 2键盘,没有运气。 问题是这些键盘在较新的计算机上工作,但在启动过程的早期键盘上的指示灯亮起后与16700B一起使用时,CAPS和NUMLOCK指示灯在其按键被按下时不起作用 - 我怀疑在那里的原因 可能是不相容的。 我已经确定了一段时间安捷伦产品代码的原始键盘和鼠标,但我恐怕最终可能会投资一个绝望的系统。 例如,我尝试从直接链接到同一路由器的计算机远程连接,但没有成功,尽管启动阶段听起来很健康。 我考虑的另一个想法是通过处理我的新LG液晶显示器的分辨率配置文件来设置外部显示器分辨率,并希望与上一个工作分辨率匹配,希望我有足够的耐心。 以上来自于谷歌翻译 以下为原文 I have tried with two vanilla PS/2 keyboards, no luck. The problem is that these keyboards work on newer computers but when used with the 16700B after a light blink on the keyboard leds early in the boot process, the CAPS and NUMLOCK lights don't work when their keys ares pressed - reason why I suspect there could be an incompatibility. I have identified for some time the Agilent product codes for the original keyboard and mouse, but I am afraid I might end up investing in a hopeless system. For example, I tried to connect remotely from a computer linked directly to the same router but without success although the booting stage sounds healthy. One more idea that I consider is to set the monitor resolution externally by working on the resolution profiles of my newer LG LCD monitor and hope there would be a match with the last working resolution, hopefully I have enough patience. |
我记得我曾经遇到过很多关于键盘和鼠标的问题,因为当时的标准并没有那么明确。
此外,16700使用了许多垂直和水平频率的疯狂组合。 当时,由于缺乏明确定义的标准,大多数人都从惠普购买推荐的显示器,而不是试图弄清楚哪些其他显示器可能有效。 我刚刚清理了我的办公室,并回收了大约10台旧HP显示器和3或4台HP-UX工作站。 一切仍然有效,但我把办公室搬到了一个较小的空间,几年来我一直没有需要它。 人 以上来自于谷歌翻译 以下为原文 I remember that I used to run into lots of problems with keyboards and mice, since the standards weren't as well-defined back then. Also, there were a lot of crazy combinations of vertical and horizontal frequencies that the 16700 used. Back then, again due to lack of well-defined standards, most people bought the recommended monitor from HP rather than try to figure out which other monitors might work. I just recently cleaned my office, and recycled some 10 old HP monitors, and 3 or 4 HP-UX workstations. Everything still worked, but I was moving the office into a smaller space, and I hadn't had a need for any of it for several years. Al |
我用以下附件成功测试了16700B系统:a)HP C3757-60401 C3757B安捷伦推荐的键盘 - 允许我启动显示器选择阶段b)PS / 2有线鼠标(Genius XScroll光学滚轮鼠标)允许
我启动X服务器。 因此,我现在可以确认系统至少对键盘类型敏感。 我不确定这是否相关,但C3757B键盘具有5.0VDC~500mA MAX规格,而另一个不成功的PS / 2键盘具有5.0VDC~50mA规格。 以上来自于谷歌翻译 以下为原文 I have tested successfully the 16700B system with the following accessories: a) the HP C3757-60401 C3757B Agilent recommended keyboard - which allowed me to initiate the monitor selection phase b) a PS/2 wired mouse (Genius XScroll Optical Wheel Mouse) which allowed me to start the X server. Therefore, I can confirm at this moment that the system is at least sensitive to the keyboard type. I am not sure if this is relevant, but the C3757B keyboard has a 5.0VDC ~ 500mA MAX spec while the other unsuccessful PS/2 keyboard had a 5.0VDC ~ 50mA spec. |
lkjflksjfsa 发表于 2019-5-15 14:38 我很高兴听到你已经开始运行了。 有些日子我真的很想念旧的基于HP-UX的设备。 然后药物消失了...... :-) Al 以上来自于谷歌翻译 以下为原文 I'm happy to hear that you're up and running. Some days I really miss messing around with the old HP-UX based gear. Then the drugs wear off... :-) Al |
1299 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1143浏览 1评论
760浏览 0评论
952浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 12:34 , Processed in 1.522478 second(s), Total 88, Slave 72 queries .
