我正在尝试设计一个斯巴达6 lx16 FT(G)256 FPGA的威廉希尔官方网站
板
1)通过JTAG头通过并行电缆/ jtag编程到非易失性存储器中。 2.)但也可以通过串行接口(即micrlaze UART)接收编程数据,用新图像重新编程。 理想情况下,微型光纤将接收新图像,并以某种方式重新编程fpga并重新配置。 这可能吗? 我听说你可以使用BPI闪存并让微网格将图像加载到闪存中,然后如果新图像编程失败,则将故障安全黄金图像作为备份。 有没有人这样做过? 以上来自于谷歌翻译 以下为原文 I'm trying to design a board where a spartan 6 lx16 FT(G)256 fpga can 1) be programmed into non-volatile memory through parallel cable/jtag through the JTAG header. 2.) but can also reprogram itself with a new image by receiving the programming data through a serial interface (ie. microblaze UART). Ideally, the microblaze would recieve the new image, and somehow reprogram the fpga and reconfigure. Is this possible? I've heard that you can use a BPI flash and have the microblaze load the image into flash and then have a failsafe golden image as a backup if the new image fails programming. Has anyone done this before? |
这是可能的,并且可以轻松完成。
配置完成后,无论是MicroBlaze还是逻辑,都可以运行BPI Flash。 并且您需要使用ICAP IP Core发送重新启动命令。 请参考“UG380_Spartan-6 FPGA配置用户指南”和Spartan-3AMultiboot触发器设计:http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm 以上来自于谷歌翻译 以下为原文 This is possible and can be easily done. After configuration, you can operate BPI Flash no matter by MicroBlaze or logic. And you need to use ICAP IP Core to send re-boot command . Please consult "UG380_Spartan-6 FPGA Configuration User Guide" and Spartan-3A Multiboot Trigger design: http://www.xilinx.com/products/boards/s3astarter/reference_designs.htm |
2463 浏览 7 评论
2854 浏览 4 评论
2315 浏览 9 评论
3399 浏览 0 评论
2496 浏览 15 评论
2033浏览 1评论
640浏览 1评论
497浏览 1评论
2046浏览 0评论
775浏览 0评论
GMT+8, 2025-1-27 18:43 , Processed in 1.112481 second(s), Total 47, Slave 41 queries .
