嗨,
为了调试系统,我需要在系统运行时动态读取Block-RAM内容.... 我只有JTAG线,我不能在FPGA中制作一个特定的块用于读取内容并通过JTAG等发送它们。 我可以使用ISMP 13.2作为工具iMPACT。 使用标准的JTAG工具有没有办法做到这一点? 当然,我现在认为读取需要时间,RAM的内容不会连贯......但那是我的问题...... 谢谢 以上来自于谷歌翻译 以下为原文 Hi, For debugging a system, I need to read Block-RAM contents dynamically, while the system is running.... I have only JTAG lines, and I can not make a specific block in the FPGA for reading the contents and send them via JTAG or whatever. I can use as tools iMPACT with ISE 13.2. Is there any way to do that using the standard JTAG tools? Of course, I now that the read will take time and that the contents of the RAM will not be coherent... but that’s my problem... Thanks |
3个回答
在设计运行时通过JTAG读回BRAM可能会破坏BRAM内容。
您需要通过发出SHUTDOWN命令来停止设计,在读回期间禁用对BRAM的读写操作。 UG332中有一个JTAG回读程序 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf 要专门回读BRAM,您需要将FAR设置为特定的BRAM loaction。 iMPACT不提供此功能,因此您需要开发自己的JTAG控制器或自定义SVF文件来执行此操作。 这不是调试设计的好方法。 我强烈建议您使用我们的调试工具(如ChipScope)进行系统调试或使用Simulation来调试您的设计。 通过JTAG回读BRAM将有很多努力来获得有限的回报。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Reading back BRAM over JTAG while your design is running will potentially corrupt the BRAM content. You would need to stop the design either by issuing a SHUTDOWN command OR disabling read and writes to your BRAM during readback. There is a JTAG readback procedure in UG332 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf To specifically read back BRAM you would need to set the FAR to the specific BRAM loaction. iMPACT does not provide this capability so you would need to develop your own JTAG contoller or customize an SVF file to do this. This is not a good route to debug your design. I would STONGLY recommend that you use our debug tools such as ChipScope for in system debug or Simulation to debug your design. Reading back BRAM over JTAG will be alot of effort for limited return. View solution in original post |
您需要通过发出SHUTDOWN命令来停止设计,在读回期间禁用对BRAM的读写操作。 UG332中有一个JTAG回读程序 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf 要专门回读BRAM,您需要将FAR设置为特定的BRAM loaction。 iMPACT不提供此功能,因此您需要开发自己的JTAG控制器或自定义SVF文件来执行此操作。 这不是调试设计的好方法。 我强烈建议您使用我们的调试工具(如ChipScope)进行系统调试或使用Simulation来调试您的设计。 通过JTAG回读BRAM将有很多努力来获得有限的回报。 以上来自于谷歌翻译 以下为原文 Reading back BRAM over JTAG while your design is running will potentially corrupt the BRAM content. You would need to stop the design either by issuing a SHUTDOWN command OR disabling read and writes to your BRAM during readback. There is a JTAG readback procedure in UG332 - http://www.xilinx.com/support/documentation/user_guides/ug332.pdf To specifically read back BRAM you would need to set the FAR to the specific BRAM loaction. iMPACT does not provide this capability so you would need to develop your own JTAG contoller or customize an SVF file to do this. This is not a good route to debug your design. I would STONGLY recommend that you use our debug tools such as ChipScope for in system debug or Simulation to debug your design. Reading back BRAM over JTAG will be alot of effort for limited return. |
2451 浏览 7 评论
2848 浏览 4 评论
2312 浏览 9 评论
3392 浏览 0 评论
2488 浏览 15 评论
1797浏览 1评论
624浏览 1评论
486浏览 1评论
2037浏览 0评论
763浏览 0评论
GMT+8, 2025-1-14 08:57 , Processed in 1.514191 second(s), Total 79, Slave 63 queries .
