嗨,我正在寻找技术支持信息,用于安装我们最近用来替换NI PCI-GPIB的GPIB(型号82350B,串行MY51430191)。
以下是我们的Senario: - Fluke / Philips PM2534万用表最初使用NI Gpib PCI卡连接到PC。 - 怀疑卡问题,请更换新的Agilent Gpib PCI卡(型号82350B,Serial MY51430191)。 - 安装IO库套件后,在套件和设备管理器中检测到已安装的卡和已确认的卡。 发现IO程序检测万用表的故障排除点 - 连接到同一个gpib卡的另一个设备(可编程电源)工作但不是万用表 - 这个Fluke / Philips PM2534万用表可以在另一个带NI卡的系统上完美运行。 (我们有两个类似的系统) - 当自动检测时,当万用表打开时,似乎检测到许多gpib地址。 从PC上卸载NI驱动程序并安装Agilent随附的所有驱动程序。 这是一个测量系统设置,包括安装了GPIB卡的PC。 第一个设备是 - Fluke / Philips PM2534万用表(GPIB Addr 09)。 当我们尝试使用NI GPIB设置时,这个设备运行正常(我们两个有类似的,我们只需更换GPIB)但是当连接到Agilent gpib卡时,它没有被正确检测到。 当自动检测时,当万用表打开并且图标上有红色X标记时,似乎检测到许多gpib地址。 我们也尝试过手动设置其他几个地址,但效果不好。 您能否建议如何配置和连接Fluke / Philips PM2534万用表。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I am seeking for technical support information for installing a GPIB (Model 82350B, Serial MY51430191) which we recently brought to replace a NI PCI-GPIB. Below is our senario: - Fluke/Philips PM2534 multi-meter connected to PC originally with NI Gpib PCI card. - Suspect card issue so replace with a new Agilent Gpib PCI card (Model 82350B, Serial MY51430191). - After installing IO library Suite, installed card and confirmed card detected both in suite and device manager. Troubleshoot points to issue of IO programme detecting multi-meter since -Another device (programmable power supply) connected to same gpib card works but not the multi-meter -This Fluke/Philips PM2534 Multi-meter works perfectly on another system with NI card.( We have Two similar systems) -When auto-detecting, many gpib address seems to be detected when multi-meter is on. NI driver is uninstalled from the PC and installed all the drivers supplied with the Agilent. This is a measurement system setup including a PC where the GPIB card is installed. First device is a - Fluke/Philips PM2534 multi-meter (GPIB Addr 09). This device is working fine when we tryed on a working NI GPIB setup (we two have similar out of one we just replace the GPIB) But when conneced wiht the Agilent gpib card it is not detected correctly. When auto-detecting, many gpib address seems to be detected when multi-meter is on with red X mark on the Icon. we also tried with few other address setting manually but didnt work well. Can you advise on how to configure and connect this Fluke/Philips PM2534 multi-meter. Thanks. 附件 |
根据您的截图,您的DMM看起来不像是支持SCPI,尤其是* IDN?
Agilent Connection Expert用于识别仪器的命令。 我将执行以下操作:1)右键单击GPIB0 :: 9 :: INSTR条目,然后选择“属性”。 取消选中表示自动识别仪器的框。 2)这如何改变场景? 你能指点我这本乐器的手册吗? 我无法在网上找到它。 以上来自于谷歌翻译 以下为原文 Based on your screenshot it doesn't look like your DMM supports SCPI, especially the *IDN? command that Agilent Connection Expert uses to identify your instrument. I would do the following: 1) right-click on the GPIB0::9::INSTR entry and choose Properties. Uncheck the box that says to auto-identify the instrument. 2) How does this change the scenario? Can you point me to the manual for this instrument? I can't find it on the web. |
1296 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1137浏览 1评论
759浏览 0评论
946浏览 0评论
1297浏览 0评论
GMT+8, 2024-12-28 02:03 , Processed in 1.501544 second(s), Total 76, Slave 60 queries .
