电子发烧友william hill官网
早上好我使用34970 DACU获取一些遥测电压和温度我使用远程接口我已经使用命令ROUTE:SCAN定义了7个通道的扫描列表,我用READ获取信号?
查询问题是此查询需要几乎2秒才能处理问题是:是否可以使用命令仅获取上面配置的扫描列表中的一个通道,以尽可能快地获取此值? 谢谢daniele 以上来自于谷歌翻译 以下为原文 Good morning I m using 34970 DACU to acquire some telemetries as voltage and temperatures I m using remote interface I have defined a scan list for 7 channels using command ROUTE:SCAN and i acquire signals with READ? query The problem is that this query takes almost 2 sec to be processed The question is: Is it possible with a command to acquire only one channel of the configured scan list above, to get this value as faster as possible? thank you daniele |
您好Daniele,您可以使用ROUT:MONitor执行此操作吗?
命令,虽然它也不会很快。 请参阅34970A命令参考中的ROUTe命令子系统的详细信息。 如果你发送READ? 命令,你不能发送任何其他命令,直到READ? 完成。 解决此问题的另一种方法是为单个通道定义扫描列表并读取它,然后重新定义扫描列表并进行扫描。 以上来自于谷歌翻译 以下为原文 Hello Daniele, You can do this with the ROUT:MONitor? command although it won't be very fast either. See the details of the ROUTe command subsystem in the 34970A Command Reference. If you send a READ? command, you can't send any other command until the READ? completes. Another way to approach this is to define the scan list for a single channel and read it and then redefine the scan list and scan it. |
1298 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1142浏览 1评论
760浏览 0评论
951浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 08:35 , Processed in 1.163669 second(s), Total 47, Slave 41 queries .
