我得到了Ngdbuild:770错误,这是“同一方向的缓冲区无法串联放置”。
但是,我确信有问题的缓冲区是并行的...而不是系列。 我在XST中也禁用了“添加I / O缓冲区”。 我在感兴趣的区域附加了RTL的图像,其中也包含错误消息。 我在这疯狂吗? 这个威廉希尔官方网站 不应该抛出这个错误。 是否还有其他可能导致此错误的内容,我没有考虑? 以上来自于谷歌翻译 以下为原文 I am getting the Ngdbuild:770 error, which is "Buffers of the same direction cannot be placed in series." However, I am sure that the buffers in question are in parallel...not series. I also have "Add I/O Buffers" disabled in XST. I have attached an image of the RTL in the area of interest which contains the error message as well. Am I going crazy here? This circuit should not be throwing this error. Is there something else that can cause this error that I am not considering? |
O,
BUFG是全局时钟缓冲器,其数量有限。 一旦进入全局时钟树,就不需要进一步的缓冲,也不需要。 它会使时钟树功率加倍,增加延迟,完全没有任何理由。 BUFG可以在任何地方驱动时钟(CLB,IOB,DSP,BRAM,IP块等)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 o, A BUFG is the global clock buffer, of which there are a limited number. Once on the global clock tree, no further buffering is needed, nor desired. It would double the clock tree power, add delay, all for no reason at all. A BUFG may drive a clock anywhere (CLB, IOB, DSP, BRAM, IP blocks, etc....). Austin Lesea Principal Engineer Xilinx San Jose |
您好,请提供错误消息中的缓冲区的完整屏幕截图。此错误仅在有两个缓冲区串联时出现.PS:您的屏幕截图不清楚。谢谢,Yash
以上来自于谷歌翻译 以下为原文 Hello, Please provide complete screenshot of buffers which are in error message. This error comes only when there are two buffers are in series. PS: Your screenshot is not clear. Thanks, Yash |
2436 浏览 7 评论
2833 浏览 4 评论
2305 浏览 9 评论
3384 浏览 0 评论
2480 浏览 15 评论
1615浏览 1评论
608浏览 1评论
473浏览 1评论
2024浏览 0评论
748浏览 0评论
GMT+8, 2025-1-6 13:02 , Processed in 1.295069 second(s), Total 80, Slave 64 queries .
