电子发烧友william hill官网
我的设计完全在Verilog中,并且已经使用Spartan FPGA进行了测试。
我将源代码提供给ASIC工厂,以实现作为ASIC使用他们(我认为)的概要工具。 我的问题是,有没有办法使用任何Xilinx工具,如核心生成器,设计摘要报告等来估算AND / OR门,翻转/触发器等的数量? 据我所知,工具集中出现的.ngc或其他文件假设Xilinx的推广,因此它们对任何其他工厂/设计公司都没用,因为它们有自己的构造。 所以我想知道是否有一种方法(ROM)根据标准术语(如“可用门”)估算ASIC的大小。 任何建议都会赞赏。 谢谢。 Bhal Tulpule 以上来自于谷歌翻译 以下为原文 I have a design that is completely in Verilog and has been tested using Spartan FPGA. I am giving the source code to an ASIC fab house to implement as an ASIC using their (I think) Synopsis tools. The question I have is, is there a way to estimate the number of AND/OR gates, flip/ flops etc. using any of the Xilinx tools such as Core generator, Design Summary reports etc. ? As i understand it, the .ngc or other files that come out out of the toolset assume Xilinx promitives and as such they are not useful for any other fab/ design house since they have their own constructs. So I would like to know if there is a way to (ROM) estimate the size of the ASIC in terms of standard terms s like "usable gates". Any suggestions would appreciated. Thanks. Bhal Tulpule |
嗨Bhal,
没门。 你会发现很多关于“门数”主题的线索。 但这里还有一件重要的事情。 如果某些HDL通过ASIC工具创建一些标准单元实现,则没有独特的结果。 这取决于综合约束。 您可以从ISE综合中了解到,您可以在区域和速度之间进行选择。 ASIC工具也是如此,它们有更多的选择,因为威廉希尔官方网站 可以分解为单个门而不是LUT。 desingn库的选择也有影响。 所以忘了它。 让工厂的设计师完成他们的工作,他们会告诉你最终的结果。 最好花时间为晶圆厂人员提供良好的设计要求。 (时钟频率,功率限制,驱动强度,I / O时序(!)等) 亲切的问候 Eilert 以上来自于谷歌翻译 以下为原文 Hi Bhal, no way. You will find a lot of threads about the "gate count" topic. But here's even one more thing important. If some HDL goes through the ASIC tools to create some standard cell implementation there's no unique result. It depends on the synthesis constraints. You know from the ISE synthesis that you can choos between area and speed. Same goes for ASIC tools and they have much more options, since the circuits are brocen down to single gates instead of LUTs. And the choice of the desingn library also has an influence. So just forget it. Let the designers at the fab do their work and they will tell you the final result. Better spend your time providing the fab people with good design requirements. (clock frequency, power limits, drive strength, I/O timings(!) etc.) Kind regards Eilert |
2424 浏览 7 评论
2826 浏览 4 评论
2294 浏览 9 评论
3375 浏览 0 评论
2465 浏览 15 评论
1238浏览 1评论
590浏览 1评论
453浏览 1评论
2006浏览 0评论
732浏览 0评论
GMT+8, 2024-12-25 16:06 , Processed in 1.833451 second(s), Total 78, Slave 62 queries .
