我想从我所有的vee pro中创建一个vxe。
测量程序,带有开始/停止/暂停/关闭按钮,如vee pro。 ,我知道如何添加开始和关闭按钮,但我如何添加停止按钮来停止测量然后再次使用启动按钮重新启动和暂停按钮相同?谢谢 以上来自于谷歌翻译 以下为原文 i want to create a vxe from all my vee pro. measurements programm with start/stop/pause/close Buttons like in vee pro. , i know how i can add start and close buttons, but how i can add stop button to stop the measurement then restart again with start button and the same for pause button? Thanks |
5个回答
嗨Chong Mei Kuan,谢谢你的帮助祝你好运,视频
以上来自于谷歌翻译 以下为原文 Hi Changmeikuan, thanks for your help Best regards, veedo |
嗨再次,我尝试过类似于我的应用程序的vee程序,但为什么停止按钮不起作用?请参阅附加的vee文件谢谢veedo
以上来自于谷歌翻译 以下为原文 Hi again, i have tried in a vee programm similar to my aplication, but why the stop button does not work? see please the attached vee file Thanks veedo 附件
嗨,我知道我正在回复一个旧线程,但我似乎无法弄清楚什么是stop.EnableOnPing = false并且start.EnableOnPing = true究竟呢?
我把这些线从公式中取出,开始/停止/退出按钮的工作方式相同。 他们在做什么? ----------------没关系,我发现它属于属性。编辑:SeriousTyro于2012年8月21日下午1:40 以上来自于谷歌翻译 以下为原文 Hi, I know I am replying to an old thread but I cannot seem figure out what stop.EnableOnPing = false and start.EnableOnPing = true exactly do? I took those lines out of the formula and the start/stop/exit button work the same. What do they do? ---------------- Nevermind, I found it under properties. Edited by: SeriousTyro on Aug 21, 2012 1:40 PM |
嗨,是的,属性窗口中有描述。
同样,它也可以在VEE帮助文件中找到。 我想你已经想出了这些但只是为了再次描述。 + start.EnableOnPing = true; +可能没有意义,因为无论如何都没有人将它设置为false。 删除+ stop.EnableOnPing = false; +虽然用户没有按下“开始”按钮,但仍会启用“停止”按钮。 -mk编辑:changmeikuan于2012年8月22日10:20 AM 以上来自于谷歌翻译 以下为原文 Hi, Yeah there is description in the Properties Window. Similarly it can be found in VEE help file too. I think you've figured out these but just to describe again. +start.EnableOnPing=true;+ may not make sense since no one set it to false anyway. Removing +stop.EnableOnPing=false;+ will make the Stop button always enabled although user has not press the Start button. -mk Edited by: changmeikuan on Aug 22, 2012 10:20 AM |
1311 浏览 0 评论
2385 浏览 1 评论
2203 浏览 1 评论
2079 浏览 5 评论
2963 浏览 3 评论
1176浏览 1评论
767浏览 0评论
979浏览 0评论
1311浏览 0评论
GMT+8, 2025-1-4 12:10 , Processed in 2.497955 second(s), Total 85, Slave 69 queries .
