Chamber Structure
The inner bladder of the chamber is made of SUS304 stainless steel plate while the outer bladder is made of A3 steel plate sprayed with plastic(linpin). A large observation window is set on the chamber door. A test hole with 25mm, or 50mm or 100mm diameter is set on the left of the chamber body. A fixable PU moving wheel is adopted on the bottom of the test chamber(linpin). Controller The temperature controller adopts fully imported (Japanese PKC) meter with touch keys. P.I.D automation calculation function is available. Cooling and Air Path Circulation System The cooler adopts original French Tecumseh fully-closed compressor(linpin). The cooling system adopts single or dual low-temperature loop system design. Standards Applied GB/T2423.1-2001 and GB/T2423.2-2001 Specs and Technical Parameters Model(cm) GDW-100 GDW-225 GDW-500 GDW-800 GDW-010 Workroom Dimensions 45*45*50 50*60*75 80*70*90 80*100*100 100*100*100 Exterior Dimensions 105*97*176.5 105*102*200 132*132*217 147*152*231.5 167*152*231.5 Power(@-40℃) 4.5(KW) 5.5 (KW) 8.0(KW) 9.0(KW) 11.0(KW) Temperature Range A:-20℃~150℃ B:-40℃~150℃ C:-60℃~150℃ D:-70℃~150℃ Fluctuation/Evenness ≤±0.5℃/≤±2℃ Temperature Rise Speed 1.0~3.0℃/min Temperature Fall Speed 0.7~1.0℃/min |
2 个讨论
1161个成员聚集在这个小组
加入小组如何用AD844运算放大器完成双二阶滤波器的Pspice仿真
4774 浏览 0 评论
PSPICE二极管Model,修改结电压参数Vj0后,仿真导通电压不变?
3610 浏览 1 评论
5122 浏览 3 评论
3380 浏览 2 评论
我给导线一个网络节点,命名为V2,请问为什么在直流扫描的时候识别不了呢?
3652 浏览 0 评论
OrCAD Capture 17.2 点击edit simulation profile没有反应
2977浏览 1评论
1453浏览 0评论
新手做pspice仿真,没有找到C3M0032120K的pspice模型,改用STW56N65M2-4_TN代替,仿真出现一堆问题,求帮助
3558浏览 0评论
4069浏览 0评论
187浏览 0评论
GMT+8, 2025-1-5 08:31 , Processed in 0.553243 second(s), Total 61, Slave 50 queries .
