扫一扫,分享给好友
AKM 公司的AK7782是集成24位5路ADC和SRC的双路音频信号处理器(DSP),同时还集成了8:2立体声输入选择器,取样速率转换器,速率高达96kHz,ADC取样频率从7.35kHz 到96kHz.本文介绍了AK7782主要特性,方框图,DSP方框图,AK7782评估板AKD7782-A主要功能,方框图,威廉希尔官方网站
图以及元件布局图。
The AK7782 is an audio digital signal processor with integrated 24bit 5ch ADCs, an 8:2 stereo input selector and sample rate converters that support 2ch inputs and the frequency up to 96kHz. The ADC supports wide range of sampling frequency from 7.35kHz to 96kHz. Two integrated audio DSPs have high performance processing speed of 2560step/fs (at 48kHz sampling), and two 6k-word delay RAMs allow surround processing, timenment adjusting and FIR filtering. As the AK7782 is a RAM based DSP, it is programmable for various user requirements. It is housed in a 100pin LQFP package. AK7782主要特性: [DSP1/DSP2] □ Word Length: 28-bits □ Instruction Cycle Time: 8.1ns (2560fs, fs=48kHz) □ Processing Step: 2560 steps (max) /fs= 48kHz, 44.1kHz (Normal Speed) 15360 steps (max) /fs= 8kHz, 7.35kHz 1280 steps (max) fs= 96kHz, 88.2kHz (Double Speed) □ Multiplier: 24 x 16 → 40-bits (double precision available) □ Divider: 24 ÷ 24 → 24-bits (floating point normalization function) □ ALU: 44-bit arithmetic operation (with 4-bit overflow margin) 24-bit arithmetic and logic operation □ Data Shift: Right shift after multiplication 1, 2, 4, 5, 8, 14, 15-bits Right shift BUS 1, 2, 3, 4, 8, 14, 15-bits Left shift after multiplication 1, 2, 3, 4, 8, 15-bits Left shift BUS 1, 2, 3, 4, 6, 8, 15-bits Indirect shifting function □ Program RAM (PRAM): 2048word x 36-bits □ Coefficient RAM (CRAM): 2048word x 16-bits □ Data RAM (DRAM): 2048word x 28-bits □ Offset Register (OFREG): 64word x 13-bits □ Delay RAM (DLRAM): 168kbit (four types) ● 6kword 28-bits ● 4kword 28-bits + 4kword 14-bits ● 3kword 28-bits + 6kword 14-bits ● 3kword 28-bits + 3kword 28-bits (Linear) □ Register: 44-bits x 4 (ACC) [for ALU] 28-bits x 12 (TMP) [DBUS connection] 28-bits x 6 steps stack (PTMP) [DBUS connection] [Stereo ADC, Common for ADC1 and ADC2] □ 24-bit 2ch x 2 □ S/(N+D): 90dB (fs=48kHz) □ D-range: 96dBA (fs=48kHz) □ S/N: 96dBA (fs=48kHz) □ 8ch bidirectional analog input selector □ High-pass filter (HPF) for DC offset cancellation □ fs=7.35kHz ~ 96kHz[Mono ADC] □ 24bit 1ch □ S/(N+D) 88dB (fs=48kHz) □ D-range 95dBA (fs=48kHz) □ S/N 95dBA (fs=48kHz) □ High-pass filter (HPF) for DC offset cancellation □ fs=7.35kHz ~ 96kHz □ Digital volume control[DSP1/DSP2 In/Output Digital Interface] □ Serial Data Input: 14ch (including ADC block) □ Serial Data Output: 16ch (each DSP outputs are 14ch) □ Microcomputer Interface: 1ch In/Out or I2C-bus[SRC, Common for SRC1 and SRC2] □ 2ch x 2 □ fs=7.35kHz ~ 96kHz [General] □ PLL □ 3.3V±0.3V, 1.8V ±0.1V □ Operational Temperature: -40℃ ~ 85℃ □ 100pin LQFP 图1.AK7782方框 图2.AK7782 DSP方框图 ( DSP1 和DSP2) AK7782评估板AKD7782-A The AKD7782-A is an evaluation board for AK7782, which is a highly integrated audio processor including 5ch 24bit ADC, 4ch SRC and two audio DSP cores. This board is composed of a main board and a sub board. It is possible to control the setting of board via USB port. RCA connectors are used for the input and output of analog signal. This board also has digital interface and can achieve the interface with digital audio system via optical connector. |
815 浏览 0 评论
1162 浏览 1 评论
2536 浏览 5 评论
2871 浏览 9 评论
2720 浏览 6 评论
1111浏览 3评论
198浏览 2评论
465浏览 2评论
379浏览 2评论
462浏览 1评论
GMT+8, 2024-12-28 03:43 , Processed in 1.011209 second(s), Total 78, Slave 59 queries .
