威廉希尔官方网站
图如下
下面是lcd1602.c文件内容: #include 《avr/io.h》#include 《util/delay.h》#define INT8U unsigned char//定义LCD1602对应的端口,方便后面使用。#define LCD1602_CTL_DDR DDRB#define LCD1602_CTL_PORT PORTB#define LCD1602_PIN PINC#define LCD1602_DDR DDRC#define LCD1602_PORT PORTC#define RS_1() LCD1602_CTL_PORT |= _BV(PB0)#define RS_0() LCD1602_CTL_PORT &= ~_BV(PB0)#define RW_1() LCD1602_CTL_PORT |= _BV(PB1)#define RW_0() LCD1602_CTL_PORT &= ~_BV(PB1)#define E_1() LCD1602_CTL_PORT |= _BV(PB2)#define E_0() LCD1602_CTL_PORT &= ~_BV(PB2)//avr忙检测void Busy_Check(){ LCD1602_DDR = 0x00; //把端口设置为输入 RS_0(); RW_1(); E_1(); _delay_us(20); while((LCD1602_PIN & 0X80) == 1); //最高位为1表示忙; E_0(); LCD1602_CTL_DDR = 0XFF; //把端口设置回输出状态}//写一个命令到lcd1602void Write_Command(INT8U CMD){ Busy_Check(); RS_0(); RW_0(); LCD1602_PORT = CMD; E_1(); E_0();}//写一个字节到lcd1602void Write_Data(INT8U DAT){ Busy_Check(); RS_1(); RW_0(); LCD1602_PORT = DAT; E_1(); E_0();}//在x位,y行,写入字符串str;void Display_String(INT8U x,INT8U y,char *Str){ INT8U len,i; if (y ==0) { Write_Command(0x80 | x); }else if (y == 1) { Write_Command(0xC0 | x); } for (i=0; i《16 && Str != ‘ ’; i++) { Write_Data(Str); } }//初始化lcd1602,在main.c中直接调用该函数就可以初始化lcd1602;void Init_LCD1602(){ LCD1602_DDR = 0XFF; LCD1602_PORT = 0X00; LCD1602_CTL_DDR |= 0X0F; LCD1602_CTL_PORT = 0X00; Write_Command(0x38); _delay_ms(15); Write_Command(0x01); _delay_ms(15); Write_Command(0x06); _delay_ms(15); Write_Command(0x0c); _delay_ms(15);} 下面是lcd1602.h的定义: #ifndef LCD1602_H_#define LCD1602_H_#define F_CPU 4000000UL#define INT8U unsigned charextern void Busy_Check();//忙检测extern void Write_Command(INT8U Command);//写指令extern void Write_Data(INT8U DATA);//写数据extern void Display_String(INT8U x,INT8U y,char *Str);//从y行x位开始按序写Str字符串extern void Init_LCD1602();//初始化LCD1602#endif 下面是main.c的内容,简单测试一下,功能是否实现 #include “lcd1602.h”int main(void){ Init_LCD1602(); Display_String(0,0,“POWER: 32.25 dBm”); Display_String(0,1,“ OR 1.007 W”); while(1);} |
2561 浏览 0 评论
1159浏览 2评论
762浏览 1评论
515浏览 0评论
272浏览 0评论
449浏览 0评论
GMT+8, 2024-12-26 22:42 , Processed in 1.495106 second(s), Total 79, Slave 61 queries .
