rtc 是可以单独供电的,通常设计rtc是带有一个纽扣电池用来给rtc供电。本次是调试rtc 的备份寄存器和备份sram,这两个都是可以在rtc不断电情况下一直保存数据。
步骤
*** Main and Backup Regulators configuration *** ================================================ [..] (+) The backup domain includes 4 Kbytes of backup SRAM accessible only from the CPU, and address in 32-bit, 16-bit or 8-bit mode. Its content is retained even in Standby or VBAT mode when the low power backup regulator is enabled. It can be considered as an internal EEPROM when VBAT is always present. You can use the HAL_PWREx_EnableBkUpReg() function to enable the low power backup regulator. (+) When the backup domain is supplied by VDD (analog switch connected to VDD) the backup SRAM is powered from VDD which replaces the VBAT power supply to save battery life. (+) The backup SRAM is not mass erased by a tamper event. It is read protected to prevent confidential data, such as cryptographic private key, from being accessed. The backup SRAM can be erased only through the Flash interface when a protection level change from level 1 to level 0 is requested. -@- Refer to the description of Read protection (RDP) in the Flash programming manual. Refer to the product datasheets for more details. 主稳压器和备用稳压器配置 ======================================= |
1828 浏览 1 评论
1640 浏览 1 评论
1109 浏览 2 评论
742 浏览 2 评论
1698 浏览 2 评论
1954浏览 9评论
763浏览 4评论
590浏览 3评论
608浏览 3评论
575浏览 3评论
GMT+8, 2025-1-1 19:37 , Processed in 1.163996 second(s), Total 77, Slave 61 queries .
