电子发烧友william hill官网
IO口配置的一般步骤
GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStruct; GPIO_InitTypeDef(IO口)是一个结构体变量,包括GPIO_Pin(u16类型),GPIOSpeed(GPIOSpeed_TypeDef 类型)和GPIOMode(GPIOMode_TypeDef 类型),之后在设置引脚时会再用到。 2. RCC时钟设置
-串口1端口(PA9/PA10)的时钟寄存器:RCC_AHB1Periph_GPIOA; 3. 设置引脚的IO功能模式和speed GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);//串口1对应引脚复用映射,GPIOA9复用为USART1 GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);//串口1对应引脚复用映射,GPIOA10复用为USART1 /* 定义USART1-TX引脚PA9 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //IO口第9脚 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推免复用输出 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOA, &GPIO_InitStructure); /* 定义USART1-RX引脚 PA10 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //IO口第10脚 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//不确定 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//不确定 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//不确定 GPIO_Init(GPIOA, &GPIO_InitStructure); 4. 串口初始化设置 USART_InitStructure.USART_BaudRate=115200;//波特率 USART_InitStructure.USART_WordLength = USART_WordLength_8b;//传输数据位数 USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位个数 USART_InitStructure.USART_Parity = USART_Parity_No;//校验位无 USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;//不用流量控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//使用接收和发送功能 USART_Init(USART1, &USART_InitStructure); //把以上设置写入寄存器中(串口1) USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启相关中断 //USART_ITConfig(USART1, USART_IT_TXE, ENABLE);//发送中断 USART_Cmd(USART1, ENABLE); //使能串口1 5. 中断设置 NVIC_InitTypeDef NVIC_InitStructure; //声明结构体变量 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //IRQ通道 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;//主优先级 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;//次优先级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//中断使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 6.中断服务程序 void USART1_IRQHandler(void) //中断函数,(重写了) { u16 DATA; USART1->SR;//防止首字符丢失 //unsigned char ch; if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET)//判断如果收到了数据,收到数据CR1中RXNE位为1,该函数的返回值为1,则执行if包含的语句 { DATA=USART_ReceiveData(USART1);//读取数据 USART_SendData(USART1,DATA);//发送读到的数据 } //while(USART_GetFlagStatus(USART1,USART_FLAG_RXNE)!=SET);//等待PC的消息 //order=USART_ReceiveData(USART1);//读取收到的消息 //USART_SendData(USART1,order);//发送消息 //while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待数据发送完 } |
1792 浏览 1 评论
1626 浏览 1 评论
1094 浏览 2 评论
732 浏览 2 评论
1682 浏览 2 评论
1943浏览 9评论
740浏览 4评论
577浏览 3评论
600浏览 3评论
562浏览 3评论
GMT+8, 2024-12-26 08:37 , Processed in 0.735918 second(s), Total 47, Slave 41 queries .
