电子发烧友william hill官网
常用命令
ifconfig eth0 up 打开eth0 网卡 ifconfig eth0 down 关闭eth0 网卡 ifconfig eth0 promisc 设置网卡eth0为混杂模式 ifconfig eth0 -promisc 取消网卡eth0的混杂模式 ifconfig eth0 192.168.1.100 设置ip地址 ifconfig eth0 hw ether 4A:13:E4:F9:79:74 设置mac地址 ifconfig eth0 192.168.1.100 设置静态ip地址 udhcpc -i eth0 动态获取ip地址 代码路径 内核代码 gmac代码: gmac代码: drivers/net/ethernet/allwinner/ sunxi-gmac.c sunxi_gmac_ops.c phy代码:(一般用内核generic的代码) linux-4.9/drivers/net/phy phy.c phy_device.c mdio_bus.c ... 配置代码 linux-4.9的适配 board.dts 730 gmac0: eth@05020000 { 731 phy-rst = <&r_pio PH 19 1 1 1 0>; 732 use_ephy25m = <1>; 733 phy-mode = "rgmii"; 734 tx-delay = <7>; 735 rx-delay = <0>; 736 status = "okay"; 737 }; 调试工具 1.ethtool ethtool -s eth0 speed 1000 duplex full autoneg on //设置1000M全双工自适应 2.brctl root@TinaLinux:/# brctl --help BusyBox v1.27.2 () multi-call binary. Usage: brctl COMMAND [BRIDGE [INTERFACE]] Manage ethernet bridges Commands: show Show a list of bridges addbr BRIDGE Create BRIDGE delbr BRIDGE Delete BRIDGE addif BRIDGE IFACE Add IFACE to BRIDGE delif BRIDGE IFACE Delete IFACE from BRIDGE setageing BRIDGE TIME Set ageing time setfd BRIDGE TIME Set bridge forward delay sethello BRIDGE TIME Set hello time setmaxage BRIDGE TIME Set max message age setpathcost BRIDGE COST Set path cost setportprio BRIDGE PRIO Set port priority setbridgeprio BRIDGE PRIO Set bridge priority stp BRIDGE [1/yes/on|0/no/off] STP on/off root@TinaLinux:/# brctl addif br-lan eth0 [ 4312.718522] br-lan: port 1(eth0) entered blocking state [ 4312.724433] br-lan: port 1(eth0) entered disabled state [ 4312.730790] device eth0 entered promiscuous mode root@TinaLinux:/# brctl delif br-lan eth0 [ 4270.518067] device eth0 left promiscuous mode [ 4270.523335] br-lan: port 1(eth0) entered disabled state eth0加入和移除网桥时都会有混杂模式的打印 br-lan网桥的配置 > Networking support > Networking options <*> 802.1d Ethernet Bridging //CONFIG_BRIDGE=y |
541 浏览 0 评论
610 浏览 0 评论
735 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS系统定制开发
1409 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS编译开发说明
777 浏览 0 评论
全志V85x硬件设计大赛作品精选第二期,快来Pick你心目中的最佳方案
92112浏览 3评论
2841浏览 1评论
5114浏览 1评论
Yuzuki Lizard 全志V851S开发板 –移植 QT5.12.9教程
16397浏览 1评论
关于全志T113开发板接7寸LCD屏幕显示异常问题的解决方案
1130浏览 1评论
GMT+8, 2024-12-25 11:08 , Processed in 0.739137 second(s), Total 46, Slave 40 queries .
