简介
MCP23017能将16位并行I/O数据和IIC串行数据相互转换;设备IIC通信频率可达1.7MHz;IIC总线上可连接8个器件共128个I/O;两个中断输出引脚,可配置为高/低/开漏有效中断输出;带有外部输入复位引脚,低有效。 MCP23017模块 模块A2、A1、A0接到GND都为0,默认为0100000x,GPIOA、GPIOB默认为输入模式。 Arduino UNO与MCP23017接线 [tr]AArduino UNOMCP23017[/tr]
测试程序 打开Arduino IDE的库管理器搜索MCP23017例程库并安装,打开toggle例程 #include #include "Adafruit_MCP23017.h" // Basic pin reading and pullup test for the MCP23017 I/O expander // public domain! // Connect pin #12 of the expander to Analog 5 (i2c clock) // Connect pin #13 of the expander to Analog 4 (i2c data) // Connect pins #15, 16 and 17 of the expander to ground (address selection) // Connect pin #9 of the expander to 5V (power) // Connect pin #10 of the expander to ground (common ground) // Connect pin #18 through a ~10kohm resistor to 5V (reset pin, active low) // Output #0 is on pin 21 so connect an LED or whatever from that to ground Adafruit_MCP23017 mcp; void setup() { mcp.begin(); // use default address 0 mcp.pinMode(0, OUTPUT); mcp.pinMode(1, OUTPUT); mcp.pinMode(2, OUTPUT); } // flip the pin #0 up and down void loop() { delay(100); mcp.digitalWrite(0, HIGH); delay(100); mcp.digitalWrite(0, LOW); delay(100); mcp.digitalWrite(1, HIGH); delay(100); mcp.digitalWrite(1, LOW); delay(100); mcp.digitalWrite(2, HIGH); delay(100); mcp.digitalWrite(2, LOW); } 总结 在MCU的IO引脚不够用时,选择MCP23017扩展更多的IO引脚与更多的设备实现连接交换数据。 |
1455 浏览 0 评论
3339 浏览 9 评论
3017 浏览 16 评论
3508 浏览 1 评论
9104 浏览 16 评论
1221浏览 3评论
632浏览 2评论
621浏览 2评论
2363浏览 2评论
1928浏览 2评论
GMT+8, 2025-1-13 18:06 , Processed in 0.888584 second(s), Total 44, Slave 35 queries .
