CPU:RK3288
系统:Android 5.1
注:系统中自带的模块没有AP6212,相近的只有AP6210,设置为AP6210,直接添加固件也可以正常使用。
此文是手动添加AP6212的例程。
1、在设备树中修改 wifi 芯片为 ap6212,
kernel/arch/arm/boot/dts/rk3288-tb_8846.dts
diff --git a/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts b/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts
index 6a65163..aa5480d 100755--- a/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts+++ b/kernel/arch/arm/boot/dts/rk3288-tb_8846.dts
@@ -42,7 +42,7 @@ * rtl8188eu, rtl8723bs, rtl8723bu * esp8089 */
- wifi_chip_type = "ap6330";+ wifi_chip_type = "ap6212";
sdio_vref = <1800>; //1800mv or 3300mv
2、在 Kconfig 文件中增加 AP6212 选项。
/kernel/drivers/net/wireless/Kconfig
diff --git a/kernel/drivers/net/wireless/Kconfig b/kernel/drivers/net/wireless/Kconfig
index 544aa86..3e1026d 100755--- a/kernel/drivers/net/wireless/Kconfig+++ b/kernel/drivers/net/wireless/Kconfig
@@ -84,6 +84,10 @@ choice
config AP6210 bool "AP6210"
depends on RKWIFI+
+ config AP6212+ bool "AP6212"+ depends on RKWIFI
config AP6234 bool "AP6234"
3、在配置文件 rockchip_defconfig 中屏蔽旧 wifi 芯片,增加新的 wifi 芯片
kernel/arch/arm/configs/rockchip_defconfig
diff --git a/kernel/arch/arm/configs/rockchip_defconfig b/kernel/arch/arm/configs/rockchip_defconfig
index e7c697a..5199ec0 100755--- a/kernel/arch/arm/configs/rockchip_defconfig+++ b/kernel/arch/arm/configs/rockchip_defconfig
@@ -299,7 +299,7 @@ CONFIG_USB_SIERRA_NET=y
CONFIG_RTL8188EU=y
CONFIG_ESP8089=y
CONFIG_RKWIFI=y-CONFIG_AP6335=y+# CONFIG_AP6335 is not set+CONFIG_AP6212=y
# CONFIG_INPUT_MOUSEDEV is not set
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_KEYRESET=y
4、此时串口打印中会出现打开文件 fw_bcm43438a1.bin 失败,需要更新 wifi 模块固件。
[ 18.686420] dhdsdio_download_code_file: Open firmware file failed /system/etc/firmware/fw_bcm43438a1.bin
[ 18.686430] _dhdsdio_download_firmware: dongle image file download failed
WiFI 固件路径:/external/wlan_loader/firmware
将模块供应商提供的固件文件拷贝到此目录下,然后编译烧录。
external/wlan_loader/firmware/fw_bcm43438a1.bin
external/wlan_loader/firmware/fw_bcm43438a1_apsta.bin
external/wlan_loader/firmware/fw_bcm43438a1_p2p.bin
external/wlan_loader/firmware/nvram_ap6212.txt
编译后,系统会将模块固件拷贝到 out/target/product/rk3288/system/etc//firmware/ 目录下
如果只是调试,可以通过 adb 将固件 push 到 /system/etc//firmware/ 目录下,然后重启。
kernel/drivers/net/wireless/rockchip_wlan/rkwifi/rk_wifi_config.c
wifi 驱动路径:kernel/net/rfkill/rfkill-wlan.c
如果器件升级,比如器件为AP6212A,供应商给的文件问 nvram_ap6212a.txt,则需要修改下面文件。(直接用以前的 nvram_ap6212.txt 也可以用,但文件不一样,不清楚)
路径:kerneldriversnetwirelessrockchip_wlanrkwifibcmdhddhd_config.c
diff --git a/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c b/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c
index 39641e1..91d7925 100755--- a/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c+++ b/kernel/drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd/dhd_config.c
@@ -477,7 +477,7 @@ dhd_conf_set_fw_name_by_chip(dhd_pub_t *dhd, char *fw_path, char *nv_path)
strcpy(&fw_path[i+1], bcm43438a0_fw_name[fw_type]); else if (chiprev == BCM43430A1_CHIP_REV)
strcpy(&fw_path[i+1], bcm43438a1_fw_name[fw_type]);- strcpy(&nv_path[j+1], "nvram_ap6212.txt");+ strcpy(&nv_path[j+1], "nvram_ap6212a.txt");break; case BCM43340_CHIP_ID: if (chiprev == BCM43340B0_CHIP_REV)
5、BT 驱动中增添代码,支持 AP6212
BT 驱动路径:kernel/net/rfkill/rfkill-bt.c
diff --git a/kernel/net/rfkill/rfkill-bt.c b/kernel/net/rfkill/rfkill-bt.c
index a1a156c..3070080 100755--- a/kernel/net/rfkill/rfkill-bt.c+++ b/kernel/net/rfkill/rfkill-bt.c
@@ -95,6 +95,8 @@ static const char bt_name[] = #else
"ap6210_24M"
#endif+#elif defined(CONFIG_AP6212)
+ "ap6212"
#elif defined(CONFIG_AP6330) "ap6330"
#elif defined(CONFIG_AP6476)@@ -266,7 +268,7 @@ static int rfkill_rk_set_power(void *data, bool blocked) struct rfkill_rk_data *rfkill = data; struct rfkill_rk_gpio *poweron = &rfkill->pdata->poweron_gpio; struct rfkill_rk_gpio *reset = &rfkill->pdata->reset_gpio;-#if defined(CONFIG_AP6210) || defined(CONFIG_AP6335)
+#if defined(CONFIG_AP6210) || defined(CONFIG_AP6212) || defined(CONFIG_AP6335) struct rfkill_rk_gpio* rts = &rfkill->pdata->rts_gpio; struct pinctrl *pinctrl = rfkill->pdata->pinctrl; #endif@@ -307,7 +309,7 @@ static int rfkill_rk_set_power(void *data, bool blocked)
msleep(20);
gpio_direction_output(reset->io, reset->enable);
}-#if defined(CONFIG_AP6210) || defined(CONFIG_AP6335)
+#if defined(CONFIG_AP6210) || defined(CONFIG_AP6212) || defined(CONFIG_AP6335) if (pinctrl != NULL && gpio_is_valid(rts->io))
pinctrl_select_state(pinctrl, rts->gpio_state);
到此 AP6212 就可以正常使用了,但是不知道供应商提供的 BT 固件应该拷贝到哪里。
CPU:RK3288
系统:Android 5.1
此文是手动添加AP6212的例程。
depends on RKWIFI+
CONFIG_RTL8188EU=y
CONFIG_ESP8089=y
"ap6210_24M"
+ "ap6212"
msleep(20);
