机器如果设置静态ip,开机广播要进入桌面后好几十秒才发出,后面发现是系统广播有被阻塞了,打如下补丁之后正常了
diff --git a/services/core/java/com/android/server/net/NetworkStatsService.java b/services/core/java/com/android/server/net/NetworkStatsService.java index 856a076..10a3b836 100644 --- a/services/core/java/com/android/server/net/NetworkStatsService.java +++ b/services/core/java/com/android/server/net/NetworkStatsService.java @@ -329,7 +329,22 @@ public class NetworkStatsService extends INetworkStatsService.Stub { // ignored; service lives in system_server } - registerPollAlarmLocked(); + // registerPollAlarmLocked(); + + Runnable fdRunnable = new Runnable() { + @Override + public void run() { + try {//必须要延时 + Thread.sleep(5000); + } catch (InterruptedException e) { + e.printStackTrace(); + } + registerPollAlarmLocked(); + } + }; + Thread thread = new Thread(fdRunnable); + thread.start(); + registerGlobalAlert(); } |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
892 浏览 0 评论
1101 浏览 1 评论
920 浏览 1 评论
2148 浏览 1 评论
3441 浏览 1 评论
GMT+8, 2024-12-27 04:44 , Processed in 0.579444 second(s), Total 72, Slave 56 queries .
