Platform: ROCKCHIP
OS: Android 6.0 Kernel: 3.10.92 main -> bootanimation_main.cpp new BootAnimation -> Bootanimation.cpp BootAnimation::threadLoop -> BootAnimation::playMusic -> property_set("ctl.start", "startup_rington"); -> //音频文件存在才会调用. 音频文件路径: /system/media/audio/startup.wav init进程去启startup_rington service, service的定义如下 rk3288/device/rockchip/common/init.rk30board.rc //默认禁止,参数表示音频文件隔多久之后开始播放,见后面脚本文件. service startup_rington /system/bin/tinyplaywav /system/media/audio/startup.wav 3 class core user system group graphics audio system disabled oneshot 编译生成: rk3288/device/rockchip/common/device.mk PRODUCT_COPY_FILES += device/rockchip/common/tinyplaywav:system/bin/tinyplaywav tinyplaywav其实是个脚本 rk3288/device/rockchip/common/tinyplaywav [kris@:~/rk3288/device/rockchip/common]$ cat tinyplaywav #!/system/bin/sh #LOG_FILE=/data/tinyplaywave.log # check input if [ $# -lt 1 ] ; then #echo "[tinyplaywav] not wav file to play!!" >> $LOG_FILE exit 1 fi //wav文件:/system/media/audio/startup.wav # set parameter WAV_FILE=$1 //休眠3秒后播放 if [ $# -eq 2 ] ; then # sleep some time #echo "[tinyplaywav] sleep $2 s" >> $LOG_FILE sleep $2 fi //最终调用的是tinyalsa工具 # play wav file #echo "[tinyplaywav] start play, wav file is: $WAV_FILE" >> $LOG_FILE //先切换到speaker tinymix -D 0 "Playback Path" "SPK" //然后播放 tinyplay $WAV_FILE -D 0 -d 0 wav文件播放时间可以根据开机动画来决定 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1106 浏览 0 评论
1278 浏览 1 评论
993 浏览 1 评论
2293 浏览 1 评论
3619 浏览 1 评论
GMT+8, 2024-12-30 04:09 , Processed in 0.878355 second(s), Total 72, Slave 54 queries .
