2.1
2.2
2.3 选择 FSP 库版本、板子型号、设备(MCU)型号、编程语言、编译器
2.4
2.5
2.6
2.7
2.8 代码生成
2.9 代码生成结果
2.10 通过MDK 打卡RASC配置软件
2.11
3.1 LED
3.2 RASC 配置gpio
属性说明:
生成代码
软件入口函数
void hal_entry(void)
led 闪烁函数
/* TODO: add your own code here */
//初始化io
R_IOPORT_Open (&g_ioport_ctrl, g_ioport.p_cfg);
while(1)
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
R_BSP_SoftwareDelay(100, BSP_DELAY_UNITS_MILLISECONDS); //延时 100毫秒
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_HIGH);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_HIGH);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_LOW);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_15, BSP_IO_LEVEL_HIGH);
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
系统延时函数
void R_BSP_SoftwareDelay (uint32_t delay, bsp_delay_units_t units)
delay:时间数量
units:时间单位
可选的时间单位
```c
typedef enum
BSP_DELAY_UNITS_SECONDS = 1000000, ///< Requested delay amount is in seconds
BSP_DELAY_UNITS_MILLISECONDS = 1000, ///< Requested delay amount is in milliseconds
BSP_DELAY_UNITS_MICROSECONDS = 1 ///< Requested delay amount is in microseconds
} bsp_delay_units_t;
fsp_err_t R_IOPORT_Open(ioport_ctrl_t * const p_ctrl, const ioport_cfg_t * p_cfg);
fsp_err_t R_IOPORT_Close(ioport_ctrl_t * const p_ctrl);
fsp_err_t R_IOPORT_PinsCfg(ioport_ctrl_t * const p_ctrl, const ioport_cfg_t * p_cfg);
fsp_err_t R_IOPORT_PinCfg(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, uint32_t cfg);
fsp_err_t R_IOPORT_PinEventInputRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t * p_pin_event);
fsp_err_t R_IOPORT_PinEventOutputWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t pin_value);
fsp_err_t R_IOPORT_PinRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t * p_pin_value);
fsp_err_t R_IOPORT_PinWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_pin_t pin, bsp_io_level_t level);
fsp_err_t R_IOPORT_PortDirectionSet(ioport_ctrl_t * const p_ctrl,
bsp_io_port_t port,
ioport_size_t direction_values,
ioport_size_t mask);
fsp_err_t R_IOPORT_PortEventInputRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t * event_data);
fsp_err_t R_IOPORT_PortEventOutputWrite(ioport_ctrl_t * const p_ctrl,
bsp_io_port_t port,
ioport_size_t event_data,
ioport_size_t mask_value);
fsp_err_t R_IOPORT_PortRead(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t * p_port_value);
fsp_err_t R_IOPORT_PortWrite(ioport_ctrl_t * const p_ctrl, bsp_io_port_t port, ioport_size_t value, ioport_size_t mask);
审核编辑 黄昊宇
