嗨,
我正在尝试在 Wemos D1 mini D4 引脚上运行中断。 使用时需要电阻/电容吗 代码:全选pinMode(buttonPin, INPUT_PULLUP); (或者只是在 gnd 和 D4 之间切换?) 而不是 1 中断我得到一个系列(尽管 FALLING 选项,我在按下和释放开关时得到中断)。 这个想法是在按下开关时中断。 代码:全选#include #include const char* ssid = "xxx"; const char* password = "xxx"; const char* mqtt_server = "192.168.1.200"; const char* mqttUser = "mosquitto"; const char* mqttPassword = "mosquitto1"; const int mqttPort = 1883; const int buttonPin = 2; volatile byte buttonState = LOW; unsigned long aktualnyCzas = 0; WiFiClient espClient; PubSubClient client(espClient); void setup() { //pinMode(buttonPin, INPUT); pinMode(buttonPin, INPUT_PULLUP); Serial.begin(115200); Serial.println("----"); WiFi.begin( ssid, password ); while (WiFi.status() != WL_CONNECTED) { delay(1); } client.setServer(mqtt_server, mqttPort); while (!client.connected()) { if (client.connect("Przycisk2", mqttUser, mqttPassword )) { } else { } } attachInterrupt(digitalPinToInterrupt(buttonPin), sendmqtt, FALLING); delay(1000); } void sendmqtt() { buttonState = 1; } void loop() { client.loop(); if (buttonState == 1) { detachInterrupt(buttonPin); buttonState=0; client.publish("ha/switch1", "ON"); aktualnyCzas = millis(); Serial.println(aktualnyCzas); delay(1000); attachInterrupt(digitalPinToInterrupt(buttonPin), sendmqtt, FALLING); } } |
321 浏览 0 评论
1178 浏览 1 评论
586浏览 6评论
483浏览 5评论
468浏览 5评论
467浏览 4评论
442浏览 4评论
GMT+8, 2024-12-27 10:08 , Processed in 1.682373 second(s), Total 73, Slave 57 queries .
