请问是否有人如何使用ESP8266 MQTT TLS Connect Azure Device Provision Service(DPS) Cloud?
目前使用ES8266 MQTT 连接MSFT Azure DPS 会无法连线,以下是我的AT CMD,想请问是否哪个步骤漏掉了,才导致不能连线? AT+MQTTUSERCFG=0,2,"NULL","NULL","NULL",0,0,"" AT+MQTTCLIENtiD=0,"wexxxxx" AT+MQTTUSERNAME=0,"0ne00xxxx/registrations/wexxxxx/api-version=2019-03-31" AT+MQTTPASSWORD=0,"SharedAccessSignature sr=0ne00xxxx%2Fregistrations%2Fwexxx&sig=4xnwmi4IabfS%2FZ5bFJSLl8sRZ5mTeI3eoU9RcNLtqgA%3D&se=12986972404&skn=enrolltest" AT+MQTTCONN=0,"global.azure-devices-provisioning.net",8883,1 因为从微软官方的文件来看,如果要连线Azure DPS 必须使用BaltimoreCyberTrustRoot CA,所以想请问如果我想更新ESP8266 MQTT root CA(BaltimoreCyberTrustRoot.crt.pem),我透过以下这篇教学,把BaltimoreCyberTrustRoot.crt.pem 转成.bin,要把该CA flash download 到以下哪个区域? 如何产生PKI REF: AT+SYSFLASH? +SYSFLASH:"factory_param",64,8,0xf1000,0x1000 +SYSFLASH:"server_cert",64,2,0xf2000,0x2000 +SYSFLASH:"server_key",64,3,0xf4000,0x2000 +SYSFLASH:"server_ca",64,4,0xf6000,0x2000 +SYSFLASH:"client_cert",64,5,0xf8000,0x2000 +SYSFLASH:"client_key",64,6,0xfa000,0x2000 +SYSFLASH:"client_ca",64,7,0xfc000,0x2000 +SYSFLASH:"wpa2_cert",64,8,0xfe000,0x2000 +SYSFLASH:"wpa2_key",64,9,0x100000,0x2000 +SYSFLASH:"wpa2_ca",64,10,0x102000,0x2000 +SYSFLASH:"mqtt_cert",64,11,0x104000,0x2000 +SYSFLASH:"mqtt_key",64,12,0x106000,0x2000 +SYSFLASH:"mqtt_ca",64,13,0x108000,0x2000 |
321 浏览 0 评论
1178 浏览 1 评论
586浏览 6评论
483浏览 5评论
468浏览 5评论
467浏览 4评论
442浏览 4评论
GMT+8, 2024-12-27 11:19 , Processed in 0.995152 second(s), Total 74, Slave 58 queries .
