我正在做我的最终学位项目,但我被灰尘传感器困住了。
在我的项目中,我必须使用 ESP12-E NodeMcu 板和三个传感器,温度和湿度 (DHT22)、VOC (CCS811) 和粒子 (PPD42)。 当我仅使用 PPD42 传感器时,返回值是正确的(范围 0 - 1000),但是当我连接三个传感器 + wifi 时,这些值要么为 0,要么太大(+1,000,000)。 你可以帮帮我吗? 代码:全选#include #include #include #include #include #include #include #include #include \"SparkFunCCS811.h\" //Click here to get the library: http://librarymanager/All#SparkFun_CCS811 #define CCS811_ADDR 0x5A //Alternate I2C Address //SEND_DATA const char* serverName = \"http://****\"; String serial_numb = \"****\"; //SEND_DATA //CCS811 CCS811 myCCS811(CCS811_ADDR); float CCS811_CO2 = 0; float CCS811_tVOC = 0; //CCS811 //for LED status #include ticker ticker; //PPD42 //Set variables for PM10 and PM2,5 readings unsigned long starttime; unsigned long triggerOnP1; unsigned long triggerOffP1; unsigned long pulseLengthP1; unsigned long durationP1; boolean valP1 = HIGH; boolean triggerP1 = false; unsigned long triggerOnP2; unsigned long triggerOffP2; unsigned long pulseLengthP2; unsigned long durationP2; boolean valP2 = HIGH; boolean triggerP2 = false; float ratioP1 = 0; float ratioP2 = 0; unsigned long sampletime_ms = 30000; float countP1; float countP2; float concLarge = 0; float concSmall = 0; //PPD42 //DHT22 #define PIN_CONEXION D3// A cuál pin está conectado el lector #define TIPO_SENSOR DHT22 // Puede ser DHT11 también DHT dht(PIN_CONEXION, TIPO_SENSOR); float DHThumid, DHTtempC = 0; //DHT22 #ifndef LED_BUILTIN #define LED_BUILTIN 13 // ESP32 DOES NOT DEFINE LED_BUILTIN #endif int LED = LED_BUILTIN; void tick() { //toggle state digitalWrite(LED, !digitalRead(LED)); // set pin to the opposite state } //gets called when WiFiManager enters configuration mode void configModeCallback (WiFiManager *myWiFiManager) { Serial.println(\"Entered config mode\"); Serial.println(WiFi.softAPIP()); //if you used auto generated SSID, print it Serial.println(myWiFiManager->getConfigPortalSSID()); //entered config mode, make led toggle faster ticker.attach(0.2, tick); } void setup() { wifi(); setup_CSS811(); } void wifi() { WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP // put your setup code here, to run once: Serial.begin(115200); //set led pin as output pinMode(LED, OUTPUT); // start ticker with 0.5 because we start in AP mode and try to connect ticker.attach(0.6, tick); //WiFiManager //Local intialization. Once its business is done, there is no need to keep it around WiFiManager wm; //reset settings - for testing // wm.resetSettings(); //set callback that gets called when connecting to previous WiFi fails, and enters Access Point mode wm.setAPCallback(configModeCallback); //fetches ssid and pass and tries to connect //if it does not connect it starts an access point with the specified name //here \"AutoConnectAP\" //and goes into a blocking loop awaiting configuration if (!wm.autoConnect(\"wifi\")) { Serial.println(\"failed to connect and hit timeout\"); //reset and try again, or maybe put it to deep sleep ESP.restart(); delay(1000); } //if you get here you have connected to the WiFi Serial.println(\"connected...yeey :)\"); ticker.detach(); //keep LED on digitalWrite(LED, LOW); } void loop() { run_PPD42(); run_CSS811(); senddata(); delay(30000); } void setup_CSS811() { Serial.begin(115200); Serial.println(); Serial.println(\"Apply DHT22 data to CCS811 for compensation.\"); Wire.begin(); //This begins the CCS811 sensor and prints error status of .beginWithStatus() CCS811Core::CCS811_Status_e returnCode = myCCS811.beginWithStatus(); Serial.print(\"CCS811 begin exited with: \"); Serial.println(myCCS811.statusString(returnCode)); //Calling .begin() causes the settings to be loaded delay(10); //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up. dht.begin(); } void run_CSS811() { //Check to see if data is available if (myCCS811.dataAvailable()) { //Calling this function updates the global tVOC and eCO2 variables myCCS811.readAlgorithmResults(); //printInfoSerial fetches the values of tVOC and eCO2 printInfoSerial(); DHTtempC = dht.readTemperature(); DHThumid = dht.readHumidity(); Serial.print(\"Applying new values (ªC, Humedad): \"); Serial.print(DHTtempC); Serial.print(\",\"); Serial.println(DHThumid); Serial.println(); //This sends the temperature data to the CCS811 myCCS811.setEnvironmentalData(DHThumid, DHTtempC); } else if (myCCS811.checkForStatusError()) { //If the CCS811 found an internal error, print it. printSensorError(); } } void printInfoSerial() { //getCO2() gets the previously read data from the library Serial.println(\"CCS811 data:\"); Serial.print(\" CO2 concentration : \"); CCS811_CO2 = myCCS811.getCO2(); Serial.print(CCS811_CO2); Serial.println(\" ppm\"); //getTVOC() gets the previously read data from the library Serial.print(\" TVOC concentration : \"); CCS811_tVOC = myCCS811.getTVOC(); Serial.print(CCS811_tVOC); Serial.println(\" ppb\"); Serial.println(\"DHT22 data:\"); Serial.print(\" Temperatura: \"); Serial.print(dht.readTemperature(), 2); Serial.println(\" ºC\"); Serial.print(\" Humedad: \"); Serial.print(dht.readHumidity(), 2); Serial.println(\"%\"); Serial.println(); } void printSensorError() { uint8_t error = myCCS811.getErrorRegister(); if (error == 0xFF) //comm error { Serial.println(\"Failed to get ERROR_ID register.\"); } else { Serial.print(\"Error: \"); if (error & 1 << 5) Serial.print(\"HeaterSupply\"); if (error & 1 << 4) Serial.print(\"HeaterFault\"); if (error & 1 << 3) Serial.print(\"MaxResistance\"); if (error & 1 << 2) Serial.print(\"MeasModeInvalid\"); if (error & 1 << 1) Serial.print(\"ReadRegInvalid\"); if (error & 1 << 0) Serial.print(\"MsgInvalid\"); Serial.println(); } } void run_PPD42() { valP1 = digitalRead(14); valP2 = digitalRead(12); if(valP1 == LOW && triggerP1 == false){ triggerP1 = true; triggerOnP1 = micros(); } if (valP1 == HIGH && triggerP1 == true){ triggerOffP1 = micros(); pulseLengthP1 = triggerOffP1 - triggerOnP1; durationP1 = durationP1 + pulseLengthP1; triggerP1 = false; } if(valP2 == LOW && triggerP2 == false){ triggerP2 = true; triggerOnP2 = micros(); } if (valP2 == HIGH && triggerP2 == true){ triggerOffP2 = micros(); pulseLengthP2 = triggerOffP2 - triggerOnP2; durationP2 = durationP2 + pulseLengthP2; triggerP2 = false; } if ((millis() - starttime) > sampletime_ms) { ratioP1 = durationP1/(sampletime_ms*10.0); // Integer percentage 0=>100 ratioP2 = durationP2/(sampletime_ms*10.0); countP1 = 1.1*pow(ratioP1,3)-3.8*pow(ratioP1,2)+520*ratioP1+0.62; countP2 = 1.1*pow(ratioP2,3)-3.8*pow(ratioP2,2)+520*ratioP2+0.62; float PM10count = countP2; float PM25count = countP1 - countP2; // first, PM10 count to mass concentration conversion double r10 = 2.6*pow(10,-6); double pi = 3.14159; double vol10 = (4.0/3.0)*pi*pow(r10,3); double density = 1.65*pow(10,12); double mass10 = density*vol10; double K = 3531.5; concLarge = (PM10count)*K*mass10; // next, PM2.5 count to mass concentration conversion double r25 = 0.44*pow(10,-6); double vol25 = (4.0/3.0)*pi*pow(r25,3); double mass25 = density*vol25; concSmall = (PM25count)*K*mass25; Serial.print(\"PM10=\"); Serial.print(concLarge); Serial.print(\", PM25=\"); Serial.println(concSmall); durationP1 = 0; durationP2 = 0; starttime = millis(); } } void senddata(){ //Check WiFi connection status if(WiFi.status()== WL_CONNECTED){ HTTPClient http; // Your Domain name with URL path or IP address with path http.begin(serverName); // Specify content-type header http.addHeader(\"Content-Type\", \"application/x-www-form-urlencoded\"); // Prepare your HTTP POST request data String httpRequestData = \"serial_numb=\" + serial_numb + \"&DHTtempC=\" + String(DHTtempC) + \"&DHThumid=\" + String(DHThumid) + \"&CCS811_CO2=\" + String(CCS811_CO2) + \"&CCS811_tVOC=\" + String(CCS811_tVOC) + \"&PM10=\" + String(concLarge) + \"&PM25=\" + String(concSmall) + \"\"; Serial.print(\"httpRequestData: \"); Serial.println(httpRequestData); int httpResponseCode = http.POST(httpRequestData); if (httpResponseCode>0) { Serial.print(\"HTTP Response code: \"); Serial.println(httpResponseCode); } else { Serial.print(\"Error code: \"); Serial.println(httpResponseCode); } // Free resources http.end(); } else { Serial.println(\"WiFi Disconnected\"); } } |
436 浏览 1 评论
1315 浏览 1 评论
600浏览 6评论
498浏览 5评论
481浏览 5评论
481浏览 4评论
466浏览 4评论
GMT+8, 2025-1-15 04:41 , Processed in 0.678283 second(s), Total 72, Slave 56 queries .
