我有这段代码适用于我的 ESP8266:
代码:全选#include #include const size_t input_buffer_length = 256; const char* ssid = "myWifi"; const char* wifiPassword = "password123"; const char* passwordToOpenDoor = "/87"; //password should begin with a slash const int doorPin = 5; const int buzzerPin = 4; const int toneDuration = 700; int numOfRequests = 0; WiFiServer server(301); //Pick any port number you like WiFiClient client; void setup() { Serial.begin(115200); delay(10); Serial.println(WiFi.localIP()); pinMode(LED_BUILTIN, OUTPUT); digitalWrite(LED_BUILTIN, 1); pinMode(doorPin, OUTPUT); digitalWrite(doorPin, 0); pinMode(buzzerPin, OUTPUT); digitalWrite(buzzerPin, 0); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, wifiPassword); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); experimental::ESP8266WiFiGratuitous::stationKeepAliveSetIntervalMs(); server.begin(); Serial.println("Server started."); Serial.println(WiFi.localIP()); } void loop() { client = server.available(); if (!client) { return; } while(!client.available()){ delay(1); } char request[input_buffer_length]; client.readBytesUntil('\r', request, input_buffer_length); Serial.println(request); if(strstr(request, passwordToOpenDoor)) {//Is password correct? GenerateResponse("Password is correct"); OpenDoor(); CorrectPasswordSound(); } //Got a GET request and it wasn't the favicon.ico request, must have been a bad password: else if (!strstr(request, "favicon.ico")) { GenerateResponse("Password is incorrect."); } } void OpenDoor() { digitalWrite(LED_BUILTIN, 0); //flash the onboard LED to help during testing. digitalWrite(doorPin, 1); delay(500); digitalWrite(LED_BUILTIN, 1); digitalWrite(doorPin, 0); } void GenerateResponse(const char *text) { Serial.println(text); client.print( "HTTP/1.1 200 OK\r\n" "Content-Type: text/html\r\n" "\r\n" "\r\n" "\r\n" " " |
431 浏览 1 评论
1299 浏览 1 评论
599浏览 6评论
498浏览 5评论
481浏览 5评论
479浏览 4评论
463浏览 4评论
GMT+8, 2025-1-13 03:58 , Processed in 0.767168 second(s), Total 74, Slave 58 queries .
