我这边要在stop模式下让LPtiM1和LPTIM2输出两路相同的PWM,不管是用LSI还是LSE都会有200us的相位差,但是不在stop模式下用内部主频的4Mhz的时钟源,就没有200us相位差,有人知道这是啥问题吗,谢谢
代码附上: while (1) { HAL_LPTIM_PWM_Start( hlptim1,32-1,16-1); HAL_LPTIM_PWM_Start( hlptim2,32-1,16-1); HAL_Delay (2500); HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON,PWR_STOPENTRY_WFI); //直接进入停止模式,中断唤醒。然后时间到了就会唤醒 /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_LPTIM1 |RCC_PERIPHCLK_LPTIM2; PeriphClkInit.Lptim1ClockSelection = RCC_LPTIM1CLKSOURCE_LSE; PeriphClkInit.Lptim2ClockSelection = RCC_LPTIM2CLKSOURCE_LSE; PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE; void MX_LPTIM1_Init(void) { /* USER CODE BEGIN LPTIM1_Init 0 */ /* USER CODE END LPTIM1_Init 0 */ /* USER CODE BEGIN LPTIM1_Init 1 */ /* USER CODE END LPTIM1_Init 1 */ hlptim1.Instance = LPTIM1; hlptim1.Init.Clock.Source = LPTIM_CLOCKSOURCE_APBCLOCK_LPOSC; hlptim1.Init.Clock.Prescaler = LPTIM_PRESCALER_DIV1; hlptim1.Init.Trigger.Source = LPTIM_TRIGSOURCE_SOFTWARE; hlptim1.Init.OutputPolarity = LPTIM_OUTPUTPOLARITY_LOW; hlptim1.Init.UpdateMode = LPTIM_UPDATE_IMMEDIATE; hlptim1.Init.CounterSource = LPTIM_COUNTERSOURCE_INTERNAL; hlptim1.Init.Input1Source = LPTIM_INPUT1SOURCE_GPIO; hlptim1.Init.Input2Source = LPTIM_INPUT2SOURCE_GPIO; if (HAL_LPTIM_Init( hlptim1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN LPTIM1_Init 2 */ /* USER CODE END LPTIM1_Init 2 */ } |
首先需要使能LSE, 然后选择LP timer1 和 2 的工作模式为 Counts internal colock events ,其次选择 external trigger .
由外部触发信号触发才能使两个LPTIM同时工作,消除相位差。 |
1885 浏览 1 评论
1663 浏览 1 评论
1149 浏览 2 评论
763 浏览 2 评论
1720 浏览 2 评论
1965浏览 9评论
790浏览 4评论
616浏览 3评论
631浏览 3评论
594浏览 3评论
GMT+8, 2025-1-14 14:10 , Processed in 0.938067 second(s), Total 81, Slave 64 queries .
