最近在调试STM32750的lwip用cubeMX生成的工程。 但是一直ping不通,[15:54:24.555]收←◆sct calling h=cyclic_timer arg=080105e4
tcpip: ip_reass_tmr() sys_timeout: 24001014 msecs=1000 handler=cyclic_timer arg=080105e4 sct calling h=cyclic_timer arg=080105fc tcpip: dns_tmr() dns_tmr: dns_check_entries sys_timeout: 24000fec msecs=1000 handler=cyclic_timer arg=080105fc sct calling h=cyclic_timer arg=080105f0 tcpip: etharp_tmr() etharp_timer sys_timeout: 24001000 msecs=1000 handler=cyclic_timer arg=080105f0 LWIP dns_init: initializing sys_timeout: 24001014 msecs=1000 handler=cyclic_timer arg=080105e4 sys_timeout: 24001000 msecs=1000 handler=cyclic_timer arg=080105f0 sys_timeout: 24000fec msecs=1000 handler=cyclic_timer arg=080105fc netif: netmask of interface �� set to 255.255.255.0 netif: GW address of interface �� set to 192.168.1.1 netif_set_ipaddr: netif address being changed netif: IP address of interface �� set to 192.168.1.35 [15:54:26.596]收←◆etharp_request: sending ARP request. pbuf_alloc(length=28) pbuf_alloc(length=28) == 30044008 etharp_raw: sending raw ARP packet. pbuf_header: old 30044028 new 3004401a (14) ethernet_output: sending packet 30044008 pbuf_free(30044008) pbuf_free: deallocating 30044008 netif: added interface st IP addr 192.168.1.35 netmask 255.255.255.0 gw 192.168.1.1 netif: setting default interface st sct calling h=cyclic_timer arg=080105e4 tcpip: ip_reass_tmr() sys_timeout: 24001014 msecs=1000 handler=cyclic_timer arg=080105e4 sct calling h=cyclic_timer arg=080105f0 tcpip: etharp_tmr() etharp_timer sys_timeout: 24001000 msecs=1000 handler=cyclic_timer arg=080105f0 sct calling h=cyclic_timer arg=080105fc tcpip: dns_tmr() dns_tmr: dns_check_entries sys_timeout: 24000fec msecs=1000 handler=cyclic_timer arg=080105fc [15:54:27.664]收←◆sct calling h=cyclic_timer arg=080105fc tcpip: dns_tmr() dns_tmr: dns_check_entries sys_timeout: 24000fec msecs=1000 handler=cyclic_timer arg=080105fc sct calling h=cyclic_timer arg=080105e4 tcpip: ip_reass_tmr() sys_timeout: 24001014 msecs=1000 handler=cyclic_timer arg=080105e4 |
这些日志显示了定时器正在周期性地调用不同的函数,包括ip_reass_tmr()、dns_tmr()和etharp_tmr()。这些函数都与网络通信有关。 无法ping通的原因可能是以下几个方面: 1. 配置错误:请确认网络配置正确,并确保正确设置IP地址、子网掩码和默认网关。还要检查是否启用了正确的网卡。 2. 硬件故障:请检查硬件连接,确保电缆连接正确,以及PHY芯片是否正确工作。同时,确保PHY芯片的引脚和功能正确配置。 3. 驱动程序问题:请确保正确配置lwIP库和相应的驱动程序。确保初始化过程正确,并且PHY驱动程序正确地与芯片通信。 4. 中断处理:请确保安装中断处理程序,以便正确处理网络中断。没有正确处理网络中断可能会导致无法正常通信。 5. 网络堆栈问题:某些时候,网络堆栈可能会出现问题。尝试重启堆栈或重新编译网络库以解决问题。 希望这些提示能帮助你找到问题所在并解决它。如果问题仍然存在,请提供更多的详细信息,以便我们能够更好地帮助你。 |
1802 浏览 1 评论
1629 浏览 1 评论
1096 浏览 2 评论
735 浏览 2 评论
1685 浏览 2 评论
1944浏览 9评论
747浏览 4评论
580浏览 3评论
602浏览 3评论
565浏览 3评论
GMT+8, 2024-12-28 07:48 , Processed in 0.630801 second(s), Total 44, Slave 38 queries .
