换了两个网络环境都是这样,下载完matter代码置换install失败,第一个CIPD就无法链接了,log如下:
WELCOME TO... █ █ ▄ █ ▄ █ █ ▀▀█████▀▀ ▄▀▀▀▄ ▄▀▀▀▄ ▄▀▀▀▀▄█ ▀▀█▀▀▀▀▀█▀▀ ▄▀▀▀▀▄ ▄▀▀ ▀█▄ ▄█▀ █ █ █ █ █ █ █ █▄▄▄▄▄▄█ █ ▀█▄ ▄█▀ █ █ █ █ █ █ █ █ █ ▄██▀▀█ █▀▀██▄ █ █ █ ▀▄▄▄▄▀█ ▀▄▄ ▀▄▄ ▀▄▄▄▄▀ █ ▀▀ █ █ ▀▀ BOOTSTRAP! Bootstrap may take a few minutes; please be patient. Downloading and installing packages into local source directory: Setting up CIPD package manager...Traceback (most recent call last): File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 857, in sys.exit(main()) File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 849, in main return EnvSetup(**vars(parse())).setup() File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 501, in setup result = step(spin) File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 598, in cipd rosetta=self._rosetta, File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 378, in init bootstrap(client, silent, rosetta=rosetta) File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 328, in bootstrap tmp.write(client_bytes(rosetta)) File "/home/edu118/work/matter/esp-matter/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 252, in client_bytes conn.request('GET', path) File "/usr/local/lib/python3.7/http/client.py", line 1229, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1275, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1224, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1016, in _send_output self.send(msg) File "/usr/local/lib/python3.7/http/client.py", line 956, in send self.connect() File "/usr/local/lib/python3.7/http/client.py", line 1384, in connect super().connect() File "/usr/local/lib/python3.7/http/client.py", line 928, in connect (self.host,self.port), self.timeout, self.source_address) File "/usr/local/lib/python3.7/socket.py", line 727, in create_connection raise err File "/usr/local/lib/python3.7/socket.py", line 716, in create_connection sock.connect(sa) OSError: [Errno 101] Network is unreachable |
440 浏览 1 评论
1398 浏览 1 评论
608浏览 6评论
506浏览 5评论
487浏览 5评论
489浏览 4评论
472浏览 4评论
GMT+8, 2025-1-24 02:35 , Processed in 0.822489 second(s), Total 78, Slave 61 queries .
