一直没搞懂PS怎样给PL提供复位和时钟,今天这个问题终于解决了~~~~~用一个简单的例子来说明一下,怎样使用PS输出的时钟和复位信号:三色流水灯
配置PS部分就不用图说明了,方法和前面的一样,在其中勾选FCLK_CLK0、FCLK_RESET0_N
生成顶层例化代码
timescale 1 ps / 1 ps
module system_wrapper
(FIXED_IO_mio,
FIXED_IO_ps_clk,
FIXED_IO_ps_porb,
FIXED_IO_ps_srstb,
pl_clk,
rst_n);
inout [53:0]FIXED_IO_mio;
inout FIXED_IO_ps_clk;
inout FIXED_IO_ps_porb;
inout FIXED_IO_ps_srstb;
output pl_clk;
output rst_n;
wire [53:0]FIXED_IO_mio;
wire FIXED_IO_ps_clk;
wire FIXED_IO_ps_porb;
wire FIXED_IO_ps_srstb;
wire pl_clk;
wire rst_n;
system system_i
(.FIXED_IO_mio(FIXED_IO_mio),
.FIXED_IO_ps_clk(FIXED_IO_ps_clk),
.FIXED_IO_ps_porb(FIXED_IO_ps_porb),
.FIXED_IO_ps_srstb(FIXED_IO_ps_srstb),
.pl_clk(pl_clk),
.rst_n(rst_n));
endmodule
新建verilog文件编写流水灯代码。
module led_flow(pl_clk,rst_n,led);
input pl_clk;//100Mhz
input rst_n;
output [2:0]led;
reg [2:0]led;
reg clk_100khz;
reg [9:0] count0;
reg clk_100hz;
reg [9:0]count1;
reg clk_1hz;
reg [6:0]count2;
always@(posedge pl_clk or negedge rst_n)
begin
if(!rst_n)
count0<=10'd1;
else if(count0<=10'd1000)
count0<=count0+1;
else count0<=10'd1;
end
begin
if(!rst_n)
clk_100khz<=0;
else if(count0<=10'd500)
clk_100khz<=1;
else clk_100khz<=0;
end
always@(posedge clk_100khz or negedge rst_n)
begin
if(!rst_n)
count1<=10'd1;
else if(count1<=10'd1000)
count1<=count1+1;
else count1<=10'd1;
end
begin
if(!rst_n)
clk_100hz<=0;
else if(count1<=10'd500)
clk_100hz<=1;
else clk_100hz<=0;
end
always@(posedge clk_100hz or negedge rst_n)
begin
if(!rst_n)
count2<=7'd1;
else if(count2<=7'd100)
count2<=count2+1;
else count2<=7'd1;
end
begin
if(!rst_n)
clk_1hz<=0;
else if(count2<=7'd50)
clk_1hz<=1;
else clk_1hz<=0;
end
always@(posedge clk_1hz or negedge rst_n)
begin
if(!rst_n)
led[2:0]<=3'b110;//led[0]<=1
else led[2:0]<={led[1:0],led[2]};
end
endmodule
重新例化顶层代码
module top(led_f,FIXED_IO_mio,FIXED_IO_ps_clk,FIXED_IO_ps_porb,FIXED_IO_ps_srstb);
output [2:0]led_f;
// output pl_clk;
//output rst_n;
wire clk;
wire reset;
system system_i
.pl_clk(clk),
.rst_n(reset));
led_flow led_flow_inst(.pl_clk(clk),
.rst_n(reset),
.led(led_f));
endmodule
生成bitstream下载到zynq,下载步骤open hardware manager->open target->open new target
然后一路NEXT到如下的界面
选择xc7z010 finish->program device进行下载。下面是结果:
网速实在不忍直视了,慢的像蜗。
