uart程序完成的功能是将你的发送的字符传回
- #define GPH2CON (*(volatile unsigned long *)0xE0200C40)
- #define GPH2DAT (*(volatile unsigned long *)0xE0200C44)
- #define GPD0CON (*(volatile unsigned long *)0xE02000A0)
- #define GPD0DAT (*(volatile unsigned long *)0xE02000A4)
- #define GPA0CON (*(volatile unsigned long *)0xE0200000)
- #define GPA1CON (*(volatile unsigned long *)0xE0200020)
- // clock
- #define APLL_LOCK (*(volatile unsigned long *)0xE0100000)
- #define MPLL_LOCK (*(volatile unsigned long *)0xE0100008)
- #define APLL_CON0 (*(volatile unsigned long *)0xE0100100)
- #define APLL_CON1 (*(volatile unsigned long *)0xE0100104)
- #define MPLL_CON (*(volatile unsigned long *)0xE0100108)
- #define CLK_SRC0 (*(volatile unsigned long *)0xE0100200)
- #define CLK_SRC1 (*(volatile unsigned long *)0xE0100204)
- #define CLK_SRC2 (*(volatile unsigned long *)0xE0100208)
- #define CLK_SRC3 (*(volatile unsigned long *)0xE010020c)
- #define CLK_SRC4 (*(volatile unsigned long *)0xE0100210)
- #define CLK_SRC5 (*(volatile unsigned long *)0xE0100214)
- #define CLK_SRC6 (*(volatile unsigned long *)0xE0100218)
- #define CLK_SRC_MASK0 (*(volatile unsigned long *)0xE0100280)
- #define CLK_SRC_MASK1 (*(volatile unsigned long *)0xE0100284)
- #define CLK_DIV0 (*(volatile unsigned long *)0xE0100300)
- #define CLK_DIV1 (*(volatile unsigned long *)0xE0100304)
- #define CLK_DIV2 (*(volatile unsigned long *)0xE0100308)
- #define CLK_DIV3 (*(volatile unsigned long *)0xE010030c)
- #define CLK_DIV4 (*(volatile unsigned long *)0xE0100310)
- #define CLK_DIV5 (*(volatile unsigned long *)0xE0100314)
- #define CLK_DIV6 (*(volatile unsigned long *)0xE0100318)
- #define CLK_DIV7 (*(volatile unsigned long *)0xE010031c)
- #define CLK_DIV0_MASK 0x7fffffff
- #define APLL_MDIV 0x7d
- #define APLL_PDIV 0x3
- #define APLL_SDIV 0x1
- #define MPLL_MDIV 0x29b
- #define MPLL_PDIV 0xc
- #define MPLL_SDIV 0x1
- #define set_pll(mdiv, pdiv, sdiv) (1<<31 | mdiv<<16 | pdiv<<8 | sdiv)
- #define APLL_VAL set_pll(APLL_MDIV,APLL_PDIV,APLL_SDIV)
- #define MPLL_VAL set_pll(MPLL_MDIV,MPLL_PDIV,MPLL_SDIV)
- //#define PLL_OFF
- // UART
- #define ULCON3 (*(volatile unsigned long *)0xE2900C00)
- #define UCON3 (*(volatile unsigned long *)0xE2900C04)
- #define UFCON3 (*(volatile unsigned long *)0xE2900C08)
- #define UMCON3 (*(volatile unsigned long *)0xE2900C0C)
- #define UFSTAT3 (*(volatile unsigned long *)0xE2900C18)
- #define UBRDIV3 (*(volatile unsigned long *)0xE2900C28)
- #define UDIVSLOT3 (*(volatile unsigned long *)0xE2900C2C)
- #define UTXH3 (*(volatile unsigned long *)0xE2900C20)
- #define URXH3 (*(volatile unsigned long *)0xE2900C24)
- #define UTRSTAT3 (*(volatile unsigned long *)0xE2900C10)
- void clock_init(void)
- CLK_SRC0 = 0x0;// close PLL
- APLL_LOCK= 0x0000FFFF;
- MPLL_LOCK = 0x0000FFFF;
- APLL_CON0 =APLL_VAL; //FOUT= MDIV * FIN / (PDIV*2^(SDIV-1)) = 0x7d*24/(0x3*2^(1-1))=1000 MHz
- MPLL_CON = MPLL_VAL;// FOUT = MDIV*FIN/(PDIV*2^SDIV)=0x29b*24/(0xc*2^1)= 667 MHz
- CLK_SRC0= 0x10001111;// FOUT = MDIV*FIN/(PDIV*2^SDIV)=0x29b*24/(0xc*2^1)= 667 MHz
- void uart_init()
- GPA0CON= 0x22222222;
- GPA1CON= 0x2222;//配置引脚为RX/TX功能
- UFCON3= 0x1;//使能FIFO
- UMCON3= 0x0;//无流控
- ULCON3= 0x3;//数据位8,无校验,停止位1
- UCON3= 0x5; //时钟为PCLK,禁止中断,使能UART收 发
- UBRDIV3= 35;//设置波特率
- UDIVSLOT3= 0x1;
- static void Delay(long count)
- volatile int i, j = 0;
- volatile static int loop = 800000000/10000;
- for(;count > 0;count--)
- for(i=0;i < loop; i++) { j++; }
- void main(void)
- GPD0CON &=~(0xF << 0);
- GPH2CON = 0x00000000;
- clock_init();
- uart_init();
- while(1)
- while (!(UFSTAT3 & 0xFF)==0)
- UTXH3= URXH3;
回帖(1)
2015-9-29 13:40:24
学习了,感谢楼主
学习了,感谢楼主
