您好! 使用AM3517在Android2.2移植ALSA声卡驱动,在录音时总是提示RecordThread: buffer overflow错误,请问是什么原因引起的? --------- beginning of /dev/log/main I/DEBUG ( 794): debuggerd: Sep 17 2011 13:18:12 --------- beginning of /dev/log/system E/ALSALib ( 797): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidPlayback W/AudioHardwareALSA( 797): Unable to attach mixer to device AndroidPlayback: No such file or directory E/ALSALib ( 797): external/alsa-lib/src/control/control.c:909:(snd_ctl_open_noupdate) Invalid CTL AndroidCapture W/AudioHardwareALSA( 797): Unable to attach mixer to device AndroidCapture: No such file or directory E/tiALSAModule( 797): ------------------------------------------------------------Open with TI ALSA module opened,use this TI ALSA module D/TIALSAModule( 797): TI ALSA module opened D/TIALSAModule( 797): Initializing devices for TI ALSA module I/CameraService( 797): CameraService started: pid=797 D/AudioHardwareALSA( 797): openOutputStream called for devices: 0x00000002 D/TIALSAModule( 797): open called for devices 00000002 in mode 0... E/ALSAControl( 797): Control 'HeadsetR Mixer AudioR2' cannot get element info: -2 E/ALSAControl( 797): Control 'HeadsetL Mixer AudioL2' cannot get element info: -2 E/TIALSAModule( 797): Initialized ALSA PLAYBACK device default I/AudioFlinger( 797): AudioFlinger's thread 0x1e288 ready to run D/TIALSAModule( 797): route called for devices 00000002 in mode 0... E/AudioHardwareALSA( 797): CALLING STANDBY E/AudioRecord( 943): set(): sampleRate 8000, channels 16, frameCount 0 E/AudioRecord( 943): AUDIO_SOURCE_MIC = 1 D/TIALSAModule( 797): open called for devices 00040000 in mode 0... E/ALSAControl( 797): Control 'Analog Left AUXL Capture Switch' cannot get element info: -2 E/ALSAControl( 797): Control 'Analog Right AUXR Capture Switch' cannot get element info: -2 E/ALSAControl( 797): Control 'Analog Capture Volume' cannot get element info: -2 E/TIALSAModule( 797): Initialized ALSA CAPTURE device default D/AcousticsModule( 797): Acoustics set_params stub called with 0. E/AudioFlinger( 797): openInput() openInputStream returned input 0x2b580, SamplingRate 8000, Format 1, Channels 10, acoustics 0, status 0 E/AudioFlinger( 797): openInput() created record thread: ID 2 thread 0xc3c8 D/dalvikvm( 850): GC_EXTERNAL_ALLOC freed 4290 objects / 260496 bytes in 194ms D/TIALSAModule( 797): route called for devices 00040000 in mode 0... W/AudioFlinger( 797): RecordThread: buffer overflow W/AudioFlinger( 797): RecordThread: buffer overflow W/AudioFlinger( 797): RecordThread: buffer overflow |
你的错误E/ALSAControl( 797): Control 'Analog Right AUXR Capture Switch' cannot get element info: -2
来自alsa_sound/ALSAControl.cpp,应该是你的driver没有写好 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
2907个成员聚集在这个小组
加入小组351 浏览 1 评论
546 浏览 2 评论
790 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
88浏览 29评论
326浏览 23评论
262浏览 20评论
211浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 05:45 , Processed in 0.487799 second(s), Total 46, Slave 40 queries .
