扫一扫,分享给好友
我用的芯片是DM6446,开发包是dvsdk_2_00_00_22,其自带的Codec Engine版本是codec_engine_2_23_01。我按照说明,将Codec Engine中的example的codec、server和app都编译通过了。因为新的需求,我更新了Codec Engine,新的版本为codec_engine_2_26_02_11,同时我也更新了相应的依赖工具。然后我再次按照说明编译example,结果codec和server都成功编译,但编译app始终出错。错误信息如下:
Info: Configuring engine named 'speech' from the info file for DSP server 'bin/ti_platforms_evmDM6446/all.x64P', located in package 'ti.sdo.ce.examples.servers.all_codecs': Target app will look for the DSP server image 'all.x64P' in its current directory. Adding codec 'viddec_copy' (ti.sdo.ce.examples.codecs.viddec_copy.VIDDEC_COPY), scratch groupId=0 Adding codec 'videnc_copy' (ti.sdo.ce.examples.codecs.videnc_copy.VIDENC_COPY), scratch groupId=0 Adding codec 'imgdec_copy' (ti.sdo.ce.examples.codecs.imgdec_copy.IMGDEC_COPY), scratch groupId=1 Adding codec 'imgenc_copy' (ti.sdo.ce.examples.codecs.imgenc_copy.IMGENC_COPY), scratch groupId=1 Adding codec 'auddec_copy' (ti.sdo.ce.examples.codecs.auddec_copy.AUDDEC_COPY), scratch groupId=2 Adding codec 'audenc_copy' (ti.sdo.ce.examples.codecs.audenc_copy.AUDENC_COPY), scratch groupId=2 Adding codec 'sphenc_copy' (ti.sdo.ce.examples.codecs.sphenc_copy.SPHENC_COPY), scratch groupId=2 Adding codec 'sphdec_copy' (ti.sdo.ce.examples.codecs.sphdec_copy.SPHDEC_COPY), scratch groupId=2 Adding codec 'scale' (ti.sdo.ce.examples.codecs.scale.SCALE_TI), scratch groupId=undefined Adding codec 'viddec2_copy' (ti.sdo.ce.examples.codecs.viddec2_copy.VIDDEC2_COPY), scratch groupId=0 Adding codec 'videnc1_copy' (ti.sdo.ce.examples.codecs.videnc1_copy.VIDENC1_COPY), scratch groupId=0 Adding codec 'imgdec1_copy' (ti.sdo.ce.examples.codecs.imgdec1_copy.IMGDEC1_COPY), scratch groupId=1 Adding codec 'imgenc1_copy' (ti.sdo.ce.examples.codecs.imgenc1_copy.IMGENC1_COPY), scratch groupId=1 Adding codec 'sphdec1_copy' (ti.sdo.ce.examples.codecs.sphdec1_copy.SPHDEC1_COPY), scratch groupId=2 Adding codec 'sphenc1_copy' (ti.sdo.ce.examples.codecs.sphenc1_copy.SPHENC1_COPY), scratch groupId=2 Adding codec 'auddec1_copy' (ti.sdo.ce.examples.codecs.auddec1_copy.AUDDEC1_COPY), scratch groupId=2 Adding codec 'audenc1_copy' (ti.sdo.ce.examples.codecs.audenc1_copy.AUDENC1_COPY), scratch groupId=2 Adding codec 'g711enc' (ti.sdo.ce.examples.codecs.g711.G711ENC), scratch groupId=2 Adding codec 'g711dec' (ti.sdo.ce.examples.codecs.g711.G711DEC), scratch groupId=2 Adding codec 'vidtranscode_copy' (ti.sdo.ce.examples.codecs.vidtranscode_copy.VIDTRANSCODE_COPY), scratch groupId=undefined Adding codec 'vidanalytics_copy' (ti.sdo.ce.examples.codecs.vidanalytics_copy.VIDANALYTICS_COPY), scratch groupId=undefined Adding codec 'viddec1_copy' (ti.sdo.ce.examples.codecs.viddec1_copy.VIDDEC1_COPY), scratch groupId=0 Adding codec 'viddec2back_copy' (ti.sdo.ce.examples.codecs.viddec2split_copy.VIDDEC2BACK_COPY), scratch groupId=0 Adding codec 'universal_copy' (ti.sdo.ce.examples.codecs.universal_copy.UNIVERSAL_COPY), scratch groupId=undefined Info: Reading DSP memory map from the info file for DSP server 'bin/ti_platforms_evmDM6446/all.x64P', located in package 'ti.sdo.ce.examples.servers.all_codecs': js: "/home/comeback/ti/codec_engine_2_26_02_11/packages/ti/sdo/ce/osal/linux/package.xs", line 50: XDC runtime error: gnu.targets.ARM.GCArmv5T: '$used' is sealed gmake[1]: *** [package/cfg/bin/ti_platforms_evmDM6446/app_remote_pv5T.xdl] Error 1 gmake: *** [/home/comeback/ti/codec_engine_2_26_02_11/examples/ti/sdo/ce/examples/apps/speech,.dlls] Error 2 gmake[1]: *** [all] 错误 2 gmake[1]: Leaving directory `/home/comeback/ti/codec_engine_2_26_02_11/examples/ti/sdo/ce/examples/apps/speech' gmake: *** [all] 错误 2 请问该如何解决这个问题? |
4个回答
***的FAQ是否有帮助? http://processors.wiki.ti.com/index.php/Codec_Engine_FAQ
Regards, Louis |
cmh8 发表于 2018-6-21 12:59 这些我都看过了,似乎没有相关的信息。 |
尝试在packages.xs注释掉下面的语句,看是否OK, 有人通过这个方法解决过一个类似错误,希望能够帮到你。 /* Conditionally load CMEM here */ // var targetMod = xdc.useModule(prog.build.target.$name); // if ((":"+targetMod.getISAChain().join(":")+":").match(/:v5T:/i)) [ xdc.useModule('ti.sdo.linuxutils.cmem.CMEM'); //] Regards, Louis |
cmh8 发表于 2018-6-21 13:17 谢谢!我也找到了这个帖子:http://e2e.ti.com/support/dsp/omap_applications_processors/f/447/t/110920.aspx。按照这个方法,编译通过了,但不知道有没有什么副作用。 |
2907个成员聚集在这个小组
加入小组351 浏览 1 评论
546 浏览 2 评论
790 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
86浏览 29评论
320浏览 23评论
262浏览 20评论
210浏览 14评论
69浏览 13评论
GMT+8, 2024-12-29 00:12 , Processed in 0.978340 second(s), Total 83, Slave 67 queries .
