你好,
我现在的情况是,对于板子从网口接受标准以太网帧,我想把C6678芯片厂家烧写的MAC地址读取出来并填写到以太网帧的源MAC地址字段。请问我可以通过什么途径获取C6678的MAC地址?我需要看哪些模块的文档?有没有设计到这块的例程?谢谢。 |
1 个讨论
如果是用于SGMII通信中的MAC地址,可以用户直接填MAC头。 如果想知道6678自带的MAC地址,可以解析bootp包中的MAC地址获得。 参考EMAC手册和BOOTLOADER手册
Ethernet-Ready Announcement Format The Ethernet-ready announcement frame is made in the form of a BOOTP request so it can use a standard format. No response is processed for this message and it is constructed so that most—if not all—BOOTP and DHCP servers will discard it. The announcement frame is sent every three seconds (the time interval between the packets varies with the clock input); no retransmission is done. The frame uses the DIX MAC Header format. The MAC header contains: • Destination MAC address = H-MAC addr (from boot parameters, normally FF:FF:FF:FF:FF:FF) • Source MAC address = this device’s MAC addr (from boot parameters) • Type = IPV4 (0x800) |
2904个成员聚集在这个小组
加入小组348 浏览 1 评论
543 浏览 2 评论
789 浏览 3 评论
660 浏览 1 评论
1140 浏览 1 评论
79浏览 29评论
273浏览 23评论
261浏览 20评论
210浏览 14评论
68浏览 13评论
GMT+8, 2024-12-27 08:03 , Processed in 0.865803 second(s), Total 44, Slave 38 queries .
