嗨,
在我的虚拟机管理程序上运行nvidia-smi时(主机插有2个K2卡),我将117W列为Power Cap。
如果我运行“nvidia-smi -a”,我可以看到功率限制设置为117.50,强制功率限制设置为117.50,最小功率限制设置为85,最大功率限制设置为125.从我看过的K2图中,他们看到了
列出225瓦功率限制(即每GPU 117.50)。
这是否意味着我可以将强制功率限制从117.50提高到125而不用担心?
以上来自于谷歌翻译
以下为原文
Hi,
When running nvidia-smi on my hypervisor (host has 2x K2 cards plugged in), I get 117W listed as Power Cap. If I run "nvidia-smi -a", I can see that Power Limit is set to 117.50, Enforced Power Limit to 117.50, Min Power Limit to 85 and Max Power Limit to 125. From the K2 diagrams I've seen, they list 225 Watt as Power Limit (ie 117.50 per GPU).
Does this mean I can increase the Enforced Power Limit from 117.50 to 125 without worry?
