我们有一个GRID K2 RAF卡,当插入服务器(ProLiant DL580 G8)时,根本不允许Linux启动。
我们尝试使用DVD安装Redhat,并且在使用GRID适配器的硬件发现期间系统挂起。 我们不得不删除卡以安装RHEL。 一旦RHEL6.8完全安装并正常工作,我们再次尝试插入卡 - 再次,系统根本无法启动! 这使得在使用GRID K2和RHEL6.8时无法安装驱动程序和任何其他操作。 以上来自于谷歌翻译 以下为原文 We have a GRID K2 RAF card that, when inserted into the server (ProLiant DL580 G8) won't allow Linux to boot at all. We tried installing Redhat using DVD and the system hangs during hardware discovery with the GRID adapter in place. We had to remove the card to install RHEL. Once RHEL6.8 was fully installed and working, we tried inserting the card again - and, once again, the system would not boot at all! This makes installing the driver and any other action impossible when using GRID K2 with RHEL6.8. |
由于RHEL 7.0及更早版本中存在一些已知问题,例如http://nvidia.custhelp.com/app/answers/detail/a_id/4165/kw/rhel%20grid,因此值得检查知识库和发行说明。
以上来自于谷歌翻译 以下为原文 IT's worth checking the knowledge base and release notes as there are some known issues in RHEL 7.0 and earlier such as http://nvidia.custhelp.com/app/answers/detail/a_id/4165/kw/rhel%20grid |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3138 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3551 浏览 4 评论
GMT+8, 2025-1-1 18:00 , Processed in 0.585522 second(s), Total 75, Slave 59 queries .
