作为该线程的后续操作:Wice Studio 5.1在Windows 7上安装:没有足够的空闲磁盘空间
我也遇到了同样的问题在版本6.2。有超过600 GB的免费,所以这不是问题。这个问题是由于CMD.EXE路径引起的吗? 昨天我参加了一个箭头研讨会,几名来自柏树的人试图让SDK安装得不走运。他们尝试了前一个线程中提到的两个项目(Env变量,从一个拇指驱动器安装),和其他一些,但没有运气。 以上来自于百度翻译 以下为原文 As a follow on to this thread: WICED Studio 5.1 Install on Windows 7: Not enough free disk space I am also encountered the same problem on version 6.2. There is more than 600GB free, so that is not the issue. Is the problem due to cmd.exe path? I was at an Arrow seminar yesterday and several people from Cypress tries to get the SDK installed with no luck. They tried both items mentioned in the previous thread (env variables, installing from a thumb drive), and a few others, but no luck. |
7个回答
我的解决方法是将.exe解压缩到一个拇指驱动器…然后从拇指驱动器启动安装程序。然后你可以告诉它安装到C:用户 [你的名字] 文件..
以上来自于百度翻译 以下为原文 My workaround is to Unzip the .EXE to a thumb-drive... then launch the installer from the thumb drive. You can then tell it to install to C:users[your name here]Documents.. |
Sang-Culrs151536336
可以尝试再次安装,并从%%TMP%WICEDIGUTION安装日志文件夹中发送安装日志的最新版本。 取决于Windows下如何设置您的/TEMP环境变量,这可能是在tM\WICDEDY安装日志中。 我们需要最新的一个,因为听起来昨天人们试图安装成功,所以会有多个日志。 一旦提供,我将与ABDA合作,看看我们能否解决这个问题。 以上来自于百度翻译 以下为原文 sjohncollins_1568336 Could you attempt to install again and send the most recent version of the install log from the: %tmp%wiced_install_log folder. Depending on how your /temp environment variable is setup under windows, this could be under temp[size=14.6667px]wiced_install_log We need the latest one as it sounds like people were trying to install yesterday with limited success, so there will be multiple logs. Once provided, I will work with abda to see if we can figure out the issue. |
wonick 发表于 2018-9-18 18:15 你好 谢谢你收看这个节目。请从昨天找到日志文件。 约翰 星期五,2018年6月8日,上午9:17:04上午PDT,MIFO & LT;社区经理@ CyPress .com & Gt;写道: #yiv4675239569 * #yiv4675239569 a #yiv4675239569 body {font-family:Helvetica, Arial, sans-serif;}#yiv4675239569 #yiv4675239569 h1, #yiv4675239569 h2, #yiv4675239569 h3, #yiv4675239569 h4, #yiv4675239569 h5, #yiv4675239569 h6, #yiv4675239569 p, #yiv4675239569 hr {}#yiv4675239569 .yiv4675239569buttonTD {} γ 柏树开发者社区 γ WISE Studio 6.2在Windows 10上安装:没有足够的空闲磁盘空间(CONT) MIFO在WICE演播室Wi-Fi/Coubowilliam hill官网 上的回复-查看完整的讨论 Sang-Culrs151536336 可以尝试再次安装,并从%%TMP%WICEDIGUTION安装日志文件夹中发送安装日志的最新版本。 这取决于你的/ TEMP环境变量设置在Windows环境下,这可能是温度 wiced_install_log下 我们需要新的一个听起来像人们试图安装昨天有限的成功,所以会有多个日志。 一次,我将同方向看我们可以找出问题。 通过回复此邮件,此邮件的回复,或者去Cypress的开发者社区的消息 通过电子邮件或在柏树社区的开发商开始在WICED工作室Wi-Fi /组合william hill官网 的新探讨 在Windows 10安装WICED Studio 6.2:没有足够的可用磁盘空间(不)在这些流:收件箱 此电子邮件发送由赛普拉斯开发者社区因为你是注册用户。 你可以订阅立即从柏树的开发者社区,或电子邮件在您的电子邮件偏好调整频率 WICED StudioOffice安装06201082018131302Y3L.Log.Zip 4.8 K WICED StudioOpLoad 06Y0720120181253Y21.Log.Zip 4.8 K WICED StudioOffice安装06Y072012018121227 20.Log.Zip 4.7 K WICED StudioOpLoad 06Y07201201010949,14Log.Zip 4.8 K 以上来自于百度翻译 以下为原文 Hello Thanks for looking in to this. Please find the log files from yesterday. John On Friday, June 8, 2018, 9:17:04 AM PDT, mifo <community-manager@cypress.com> wrote: #yiv4675239569 * #yiv4675239569 a #yiv4675239569 body {font-family:Helvetica, Arial, sans-serif;}#yiv4675239569 #yiv4675239569 h1, #yiv4675239569 h2, #yiv4675239569 h3, #yiv4675239569 h4, #yiv4675239569 h5, #yiv4675239569 h6, #yiv4675239569 p, #yiv4675239569 hr {}#yiv4675239569 .yiv4675239569button td {} |
| WICED Studio 6.2 Install on Windows 10: Not enough free disk space (con't) reply from mifo in WICED Studio Wi-Fi/Combo Forums - View the full discussion sjohncollins_1568336 Could you attempt to install again and send the most recent version of the install log from the: %tmp%wiced_install_log folder. Depending on how your /temp environment variable is setup under windows, this could be under tempwiced_install_log We need the latest one as it sounds like people were trying to install yesterday with limited success, so there will be multiple logs. Once provided, I will work with abda to see if we can figure out the issue.
This email was sent by Cypress Developer Community because you are a registered user. You may unsubscribe instantly from Cypress Developer Community, or adjust email frequency in your email preferences
wonick 发表于 2018-9-18 18:15 它与环境变量点一起工作到Stass32文件夹。问题解决了。 谢谢你的努力 约翰 星期五,2018年6月8日,上午9:56:56 PDT,john collins & lt;ShanCluls@ @雅虎.com写道: 你好 谢谢你收看这个节目。请从昨天找到日志文件。 约翰 星期五,2018年6月8日,上午9:17:04上午PDT,MIFO & LT;社区经理@ CyPress .com & Gt;写道: TiCa,Arial,SAN-serif;} YV6633 17314 H1,YYV68033 17314 H2,YYV68033 17314 H3,YYV68033 17314 H4,YYV68033 17314 H5,Y YV68033 17314 H6,Y YV6633 173314 P,YIV68033 17314 HR {} yIV68017314Butt TD{} YYV680317314** YIV68033 17314 A YYV68033 17314机身{字体系列:Helv. γ 柏树开发者社区 γ WISE Studio 6.2在Windows 10上安装:没有足够的空闲磁盘空间(CONT) MIFO在WICE演播室Wi-Fi/Coubowilliam hill官网 上的回复-查看完整的讨论 Sang-Culrs151536336 你可以尝试重新安装,将安装日志从最新版本:% % wiced_install_log TMP文件夹。 这取决于你的/ TEMP环境变量设置在Windows环境下,这可能是温度 wiced_install_log下 我们需要新的一个听起来像人们试图安装昨天有限的成功,所以会有多个日志。 一次,我将同方向看我们可以找出问题。 通过回复此邮件,此邮件的回复,或者去Cypress的开发者社区的消息 通过电子邮件或在柏树社区的开发商开始在WICED工作室Wi-Fi /组合william hill官网 的新探讨 在Windows 10安装WICED Studio 6.2:没有足够的可用磁盘空间(不)在这些流:收件箱 此电子邮件发送由赛普拉斯开发者社区因为你是注册用户。 你可以订阅立即从柏树的开发者社区,或电子邮件在您的电子邮件偏好调整频率 以上来自于百度翻译 以下为原文 It works with environment variable point to Systems32 folder. Problem solved. Thanks for your efforts John On Friday, June 8, 2018, 9:56:56 AM PDT, john collins <sjohncollins@yahoo.com> wrote: Hello Thanks for looking in to this. Please find the log files from yesterday. John On Friday, June 8, 2018, 9:17:04 AM PDT, mifo <community-manager@cypress.com> wrote: #yiv6803317314 * #yiv6803317314 a #yiv6803317314 body {font-family:Helvetica, Arial, sans-serif;}#yiv6803317314 h1, #yiv6803317314 h2, #yiv6803317314 h3, #yiv6803317314 h4, #yiv6803317314 h5, #yiv6803317314 h6, #yiv6803317314 p, #yiv6803317314 hr {}#yiv6803317314 .yiv6803317314button td {} |
Sang-Culrs151536336 你能提供一个关于环境变量的细节来解决这个问题吗?我昨天检查了你的“CMD.exe”变量,和我自己的变量相同,我没有经历过这个问题。像这样的截屏是完美的: 阿坝 以上来自于百度翻译 以下为原文 sjohncollins_1568336 Can you provide a little detail on which environment variable you added which resolved this issue? I checked your "cmd.exe" variable yesterday and it was identical to my own, and I do not experience the issue. A screen shot like this would be perfect: abda |
wonick 发表于 2018-9-18 18:45 迈克 这是屏幕截图。 约翰 2018月8日,,,11:48:23 AM PDT,mifo <;mifo @柏。com >;写的: # yiv7851630957 * # yiv7851630957一# yiv7851630957体{字体:黑体,Arial,sans-serif;} # yiv7851630957 # yiv7851630957 H1,H2 # yiv7851630957,# yiv7851630957 H3,H4 # yiv7851630957,# yiv7851630957 H5、H6 # yiv7851630957,# yiv7851630957 P,# yiv7851630957 HR # yiv7851630957 yiv7851630957button { }。TD {} γ 柏树开发者社区 γ 你已经提到过 通过mifo回复:回复:在Windows 10安装WICED Studio 6.2:没有足够的可用磁盘空间(不)在赛普拉斯开发者社区-你的观点mifo参考 Sang-Culrs151536336 你能提供一个小的细节,你的环境变量添加解决这个问题?我检查了你的命令。exe”变昨天和它是我自己的一样,我没有经验的问题。像这样的截屏是完美的: https://community.cypress.com/servlet/jiveservlet/downloadimage/2-159150-270587/pastedimage_0.png 阿坝 通过回复这封邮件参加对话 此电子邮件发送由赛普拉斯开发者社区因为你是注册用户。 你可以订阅立即从柏树的开发者社区,或电子邮件在您的电子邮件偏好调整频率 1528 318.9 K 以上来自于百度翻译 以下为原文 Mike Here is the screen shot. John On Friday, June 8, 2018, 11:48:23 AM PDT, mifo <mifo@cypress.com> wrote: #yiv7851630957 * #yiv7851630957 a #yiv7851630957 body {font-family:Helvetica, Arial, sans-serif;}#yiv7851630957 #yiv7851630957 h1, #yiv7851630957 h2, #yiv7851630957 h3, #yiv7851630957 h4, #yiv7851630957 h5, #yiv7851630957 h6, #yiv7851630957 p, #yiv7851630957 hr {}#yiv7851630957 .yiv7851630957button td {} |
| You have been mentioned by mifo in Re: Re: WICED Studio 6.2 Install on Windows 10: Not enough free disk space (con't) in Cypress Developer Community - View mifo's reference to you sjohncollins_1568336 Can you provide a little detail on which environment variable you added which resolved this issue? I checked your "cmd.exe" variable yesterday and it was identical to my own, and I do not experience the issue. A screen shot like this would be perfect: https://community.cypress.com/servlet/JiveServlet/downloadImage/2-159150-270587/pastedImage_0.png abda
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
429浏览 2评论
440浏览 2评论
390浏览 2评论
931浏览 2评论
GMT+8, 2024-12-27 13:37 , Processed in 1.169952 second(s), Total 87, Slave 71 queries .
