扫一扫,分享给好友
你好,
我想知道我的代码是否真正安全与我的PSoC4。我读了一篇关于PSOC4关于内部安全失败的文章。这就是链接 DMITRY.GR 我的IP保护真的在PSoC4里面吗? 谢谢 以上来自于百度翻译 以下为原文 Hi, I want to know if my code is really secure with my psoc4. I read an article about an psoc4 regarding a failure in internal security. This is the link Dmitry.GR Is really my IP protected inside a PSOC4? Thanks |
因为你可以通过设置调试IO引脚GPIO将没有访问排在你的链接的文章调试。
当受保护的正确是没有机会拿到你的程序。一个代码的逆向工程将永远不会让你有可用的源代码。 所以你应该照顾你的电脑不被黑和源被偷。 鲍勃 以上来自于百度翻译 以下为原文 Because you can disable debugging by setting the debug IO pins to GPIO there will be no access as lined out in your linked article. When protected correctly there is no chance to get hands on your program. A reverse engeneering of the code will never get you to something usable as the source code is. So you should care for your PC not getting hacked and the sources get stolen. Bob |
如果您采取适当的步骤将单元设置为“杀戮”模式,并且将GPIO引脚设置为IO(未调试),那么任何试图访问Flash代码的人都将:
1)烧毁芯片 2)花很长时间仔细拆开显微镜碎片,然后很可能烧掉芯片。 3)尝试模仿代码的功能,但没有实际代码,只能对代码进行处理。这只是经过长时间的测试和拨号在芯片上,因为你的代码运行。(月/年) 以上来自于百度翻译 以下为原文 If you take the proper steps to set the unit to "Kill" mode, and the GPIO pins set to IO (NOT DEBUG), then anyone who attempts to get access to your flash code will either: 1) Burn the chip 2) Spend years to carefully pull apart the microscopic pieces, and most likely burn the chip anyways. 3) Try to mimic the functionality of your code, but without having the actual code, will only have a passable mimicry of what your code handles/does. This only after a long period of testing and poking at the chip as your code runs. (months/years) |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
429浏览 2评论
440浏览 2评论
390浏览 2评论
926浏览 2评论
GMT+8, 2024-12-27 08:47 , Processed in 1.026140 second(s), Total 80, Slave 64 queries .
