英伟达
何禄蔓
7年用户 156经验值
特斯拉M10 GPU简介问题
你好,
我有三张Tesla M10 GPU卡。
三个Cisco USC主机中的一个。
我一直在使用此配置文件图表作为部署指南:http://imgur.com/a/pVK3Q我虽然对图表有点困惑。
我不太了解最后两个列 - 每个GPU的最大vGPU和
每块板最大vGPU。
我正在寻找的是我从每张卡上获得的VM数量。
大约60个VM将分享这3张卡,我很好奇哪个配置文件最适合这个。
对此图表或概况的任何澄清都会很棒。
谢谢!
链接到我一直在使用的图表:http://imgur.com/a/pVK3Q
以上来自于谷歌翻译
以下为原文
Hello,
I have three Tesla M10 GPU cards.  One in each of three Cisco USC hosts.  I have been using this profile chart as guidance for deployment: http://imgur.com/a/pVK3Q   I'm a bit confused with the chart though.  I don't quite understand the last two colums - Max vGPUs per GPU & Maximum vGPUs per board.
What I'm looking for is the amount of VM's I can get from each card.  Around 60 VM's will be sharing these 3 cards and I'm curious which profile would be best suited for this.
Any clarification of this chart or the profiles in general would be great.
Thanks!
Link to the chart I've been using: http://imgur.com/a/pVK3Q
回帖(4)
莫钻红
2018-9-20 11:46:08
你好
M10(主板)上有4个GPU。
使用1GB配置文件(您需要最小1GB配置文件以便使用NVenc),每个GPU可以获得8个VM和/或每个板可以获得32个VM(8x4 = 32)。
如果您使用2GB配置文件,每个主板将获得16个VM,因此您将无法为每个服务器支持20个用户。
除非您使用RDS,否则1GB是您唯一的选择。
至于最佳配置文件大小,这取决于应用程序,操作系统,有多少显示器及其分辨率。
需要考虑很多因素。
从1GB开始,看看是否足够,但如上所述,如果你更高,你将不会得到每个服务器20(并发)用户。
问候
以上来自于谷歌翻译
以下为原文
Hi
The M10 (the board) has 4 GPUs on it.
Using a 1GB Profile, (you'll need a 1GB Profile minimum so you can use NVenc) you can get 8 VMs per GPU and / or 32 VMs per board (8x4=32). If you use a 2GB Profile, you'll get 16 VMs per board, so you won't be able to support 20 users per server. 1GB is your only option, unless you use RDS.
As for the best Profile size, that depends on the applications, Operating System, how many monitors and their resolution. Lots of factors to consider. Start with 1GB and see if that's enough, but as said, if you go any higher, you won't get 20 (concurrent) users per server.
Regards
李荣
2018-9-20 11:54:39
谢谢回复。
当你说1GB和2GB的配置文件 - 图表上的位置或者你如何区分它?
抱歉这个愚蠢的问题。
以上来自于谷歌翻译
以下为原文
Thanks for the reply.  When you say 1GB and 2GB profile - where is that on the chart or how are you distinguishing that?  Sorry for the silly question.
孙灿
2018-9-20 12:10:52
在“GRID虚拟GPU”标题下,也在“Frame Buffer”标题下;-)
vGPU配置文件在GB中分配“帧缓冲区”... 0,1,2,4,8(0 = 512MB,这不值得打扰)。
以上来自于谷歌翻译
以下为原文
Under the heading "GRID virtual GPU" and also under the heading "Frame Buffer" ;-)
The vGPU profiles allocate "Frame Buffer" in GBs ... 0, 1, 2, 4, 8 (0 = 512MB, which is not worth bothering with).
庞书娟
2018-9-20 12:21:28
啊哈!
再次感谢!
以上来自于谷歌翻译
以下为原文
ah ha!  thanks again!
