英伟达
何禄蔓
7年用户 156经验值
怎么查看GPU利用率(Tesla M10 + VMware)
我在三台Cisco UCS主机上安装了3个Tesla M10 GPU。
它们被用于Horizo​​n 7中的一个池中,覆盖80多个独立的VM。
我的任务是看看GPU的使用量。
当我运行nvidia-smi时,它显示100%的所有内容,但我很难相信考虑到许多VM当前没有运行。
有什么我想念的吗?
以上来自于谷歌翻译
以下为原文
I have 3 Tesla M10 GPUs on three Cisco UCS hosts.  They are being used in one pool in Horizon 7 across 80+ separate VM's.  I have been tasked with seeing how much the GPU's are being utilized.  When I run nvidia-smi it show's everything at 100% but I have a hard time believing that considering many of the VM's are not currently running.  Is there something I'm missing?
回帖(6)
刘先睿
2018-9-30 10:55:47
你在哪里经营nvidia-smi?
主持人还是客人?
您使用的是哪种配置文件?
我不相信你的所有GPU都在100%运行...
以上来自于谷歌翻译
以下为原文
Where do you run nvidia-smi? Host or guest? Which profile are you using?
I don't believe that all of your GPUs are running at 100% all the time...
魏荣梅
2018-9-30 11:15:11
您是否尝试过安装并运行不错的免费实用程序GPUprofiler?
以上来自于谷歌翻译
以下为原文
Have you tried installing and running the nice free utility, GPUprofiler ?
高川
2018-9-30 11:22:19
当您运行VMware时,如果您查看GRID软件门户(您从中添加软件),请在产品信息> 5.2> ...下面找到“用于vRealize Operations的NVIDIA虚拟GPU管理包”。
如果您正在运行vROP,这将为您提供一些出色的监控功能。
否则,正如Tobias所提到的,GitHub上的GPUProfiler也非常好!
问候
以上来自于谷歌翻译
以下为原文
As you're running VMware, if you look in the GRID Software Portal (where you doenloaded the software from), under Product Information > 5.2 > ... There's an "NVIDIA Virtual GPU Management Pack for vRealize Operations".
This will give you some great monitoring capabilities if you're running vROPs. Otherwise as Tobias mentions, GPUProfiler on GitHub is very good as well!
Regards
李元宵
2018-9-30 11:41:06
你有没有想过这个?
我的P40卡在做同样的事情时遇到了问题。
以上来自于谷歌翻译
以下为原文
Have you figured this one out?  I am having problems with my P40 cards doing the same thing.
