大家好。
是否可以将冷却风扇添加到被动Grid K2? 根据我的服务器供应商,我需要主动冷却。 感谢您的时间。 以上来自于谷歌翻译 以下为原文 Hello everyone. Is it possible to add cooling fans to a passive Grid K2? According to my server vendor, I need active cooling. Thank you for your time. |
4个回答
嗨约翰尼,
可能是可能的,但肯定不支持! 寻找联想K2s,了解主动冷却K2的外观。 问候 西蒙 以上来自于谷歌翻译 以下为原文 Hi Johnny, might be possible but for sure not supported! Look for the Lenovo K2s to see how the active cooled K2s look like. Regards Simon |
西蒙你好
谢谢你的回复。 为了澄清,你恳请我看一下“联想K2”。 这是否意味着他们联想加入了粉丝而不是NVIDIA? 我认为从后者购买时,购买带有主动冷却的K2是一种选择。 以上来自于谷歌翻译 以下为原文 Hello Simon. Thank you for replying. To clarify, you kindly suggested I look at a "Lenovo K2." Does that mean they, Lenovo, added the fans rather than NVIDIA? I assumed buying a K2 with active cooling was an option when purchasing from the latter. |
或者选择被动冷却选项,如P4,如果这是您的服务器可以支持的。
以上来自于谷歌翻译 以下为原文 Or go for a passively cooled option, like a P4, if that's something your server can support. |
好吧,托比亚斯。
不幸的是,即使我有足够大的预算,我也没有,我将使用的服务器不支持P4。 我只是想了解联想是否将风扇添加到直接从他们那里购买的K2卡,或者当NVIDIA将它们出售给联想时添加它们(可能作为选项)。 以上来自于谷歌翻译 以下为原文 Hi again, Tobias. Unfortunately, even if I had a big enough budget, which I don't, the server I'll be using doesn't support the P4. I was just trying to understand whether or not Lenovo added fans to K2 cards purchased directly from them, or if NVIDIA added them, perhaps as an option, when they sold them to Lenovo. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3138 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3551 浏览 4 评论
GMT+8, 2025-1-1 18:27 , Processed in 0.705472 second(s), Total 82, Slave 66 queries .
