我们使用BCM433芯片,并通过WICE 3.7.0~7实现蓝牙连接的过程。在该部分的数据表中,在第115页,它指出“BCM4340不提供同时2.4 GHz和5 GHz的操作”。由于BLE被放置在芯片的2.4GHz部分,这个陈述是否意味着如果使用5GHz AP来进行WiFi接入,那么BLE就不能使用?
以上来自于百度翻译 以下为原文 We use a BCM43340 chip and are in the process of implementing bluetooth connection through WICED 3.7.0-7. In the datasheet for the part, on page 115, it states that "The BCM43340 does not provide simultaneous 2.4 GHz and 5 GHz operation". Since the BLE is housed in the 2.4GHz portion of the chip, does this statement mean that BLE cannot be used if using a 5GHz AP for wifi access? |
你的理解是正确的。数据表和示意图似乎表明,如果使用5 GHz AP用于WiFi接入,则不能使用BLE。验证这一点的一种方法是测试BLYWiFixIdvor应用程序,在那里连接到5 GHz AP并检查连接是否被维护。
以上来自于百度翻译 以下为原文 Your understanding is correct. The datasheet and schematic seem to indicate that BLE cannot be used if using a 5 GHz AP for wifi access. One way to validate this is by testing the ble_wifi_introducer App where you connect to a 5 GHz AP and check the connection is maintained or not. |
chm5 发表于 2018-10-24 10:42 CrSON.KRUPPE223 29 926 RROY 我在内部检查了WiFi组合芯片产品团队,它似乎所有我们目前的组合设备(如CYW4345和其他)利用分立PHY,MAC和共享天线,所以5GHz的无线局域网和2.4GHz的BT同时是可能的(即5G SwiTAP与BLE)。 我们有一个设备,今年晚些时候,可以利用一个双天线路径和LNA,这将是最佳的2.4GHz无线局域网和同时BT。 记住,原来的问题是同时引用5GHz WLAN和2.4GHz BT,而不是2.4GHz WLAN和5GHz无线局域网——这只有RSDB才可能。 希望这有帮助。 以上来自于百度翻译 以下为原文 carson.krupp_2329926 rroy I checked internally with the WiFi Combo chip product team and it appears that all of our current combo devices (ex. CYW43455 and others) leverage a seperate PHY, MAC and shared antenna, so 5GHz WLAN and 2.4GHz BT simultaneously is indeed possible (i.e. 5G softAP with BLE). We have a device coming out later in the year which can take advantage of a dual antenna path and LNAs, and this will be optimal for 2.4GHz WLAN and simultaneous BT. Remember though that the original question references 5GHz WLAN and 2.4GHz BT simultaneously – not 2.4GHz WLAN and 5GHz WLAN – that’s only possible with RSDB. Hope this helps. |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
428浏览 2评论
440浏览 2评论
390浏览 2评论
922浏览 2评论
GMT+8, 2024-12-26 21:39 , Processed in 0.694432 second(s), Total 47, Slave 41 queries .
