用ad8367设计俩级级联的VGA威廉希尔官方网站
,当输入信号大于20M时,第一片输出的信号会有一个很小的波动,到第二级输出波形完全失真,抖动的非常厉害,俩级间也加了由电阻搭的平衡网络。尝试了很多方法,但是都不能解决问题。
您好,您的问题已经提交给ADI相关专家,将邀请专家尽快回答您的问题。谢谢!
您好!
对于AD8367两级级联,产品线工程师建议如下,供您参考。 This is not the first time cascaded AD8367 have been used to extend the dynamic range. There are a few things one must keep in mind while cascading the VGAs to extend the dynamic range: 1) The input linearity of the cascade will be very low at high gain settings 2) The sensitivity will be poor at low gain settings 3) High max gain and high bandwidth devices like the AD8367 may be potentially unstable, and it may be necessary to apply some resistive padding between the stages to ensure a stable solution. Starting with the third point, it will likely be necessary to add ~10dB of padding between the two VGA's (or all three VGAs if you need it, right now, I’ll just speak to two cascaded VGAs). The AD8367 needs to be sourced and loaded in a 200-Ohm impedance environment to ensure stability. However, the output of the AD8367 presents a 50-Ohm impedance. If you directly cascade the devices the 2nd stage VGA will be presented by the 50-Ohm impedance of the first stages output, and may cause the 2nd stage to oscillate. As a result a 200-Ohm to 200-Ohm resistive pad will likely be needed between the two stages. A 10dB pad should be enough to isolate the 50-Ohm source impedance of the first stage VGA from the input of the second stage. If the cascade is properly stabilized, you should be able to achieve ~90dB of gain adjustment range. |
1034 浏览 2 评论
1421 浏览 2 评论
1959 浏览 1 评论
4285 浏览 2 评论
9086 浏览 1 评论
1622浏览 3评论
1711浏览 2评论
1035浏览 2评论
1702浏览 2评论
1421浏览 2评论
GMT+8, 2025-1-6 18:30 , Processed in 0.756049 second(s), Total 78, Slave 62 queries .
