我需要使用NULL工具测量dB的相对电平变化。
但是当我测量例如-6.00 dBm并按下NULL时,我预计读数为0.00 dB,但是仪表显示-100 dB左右的非常波动的值! (一个ACV值可以是空的很好。)任何人都有这个解决方案?编辑:Arnoldus于2014年8月22日上午10:02 以上来自于谷歌翻译 以下为原文 I need to measure a relative level change in dB using the NULL facility. But when I measure eg -6.00 dBm and press NULL, I expect a reading of 0.00 dB, but the meter shows a very fluctuating value around -100 dB! (An ACV value can be NULL-ed fine.) Anybody has a solution for this? Edited by: Arnoldus on Aug 22, 2014 10:02 AM |
5个回答
困惑在这里A您是否尝试在直流电压上测量dB?
不要以为我听说过这个,似乎是矛盾的吗? 申请是什么? 我猜-100dB是bg噪音? acV显然确定罗宾 以上来自于谷歌翻译 以下为原文 Puzzled here A Are you trying to measure dB on dc V? Dont think Ive heard of this, seems contradictory? Whats the application? I guess -100dB is bg noise? acV obviously ok Robin |
嗨罗宾,谢谢你的回复,但-6dBm一直是Vac,对Vdc确实没有意义:-)我想测量放大器的-6dB点,所以想要读取@ 1KHz的NULL,并改变 显示频率直到-6dB。 (当我将Vac读取为NULL时,读数为0.0000 :-)我的Fluke 45使用dB函数中的REL函数完成工作。 我想34461A上的NULL必须和Fluke45上的REL做同样的事情,但事实并非如此! 阿诺德 以上来自于谷歌翻译 以下为原文 Hi Robin, Thank you for your reply, but -6dBm has always been Vac, has no sense on Vdc indeed :-) I want to measure the -6dB points of an amplifier, so want to NULL the reading @ 1KHz, and change the frequency until -6dB is shown. (When I NULL an Vac reading, the reading is 0.0000 :-) My Fluke 45 does the job well, using the REL function in dB's. I suppose NULL on the 34461A has to do the same as REL on a Fluke45, but is doesn't ! Arnold |
tan8561 发表于 2018-11-5 13:03 你好A你在使用“数学”功能吗? 这将带你去Vac上的dBm设置为50Hz的空值使用测量ref val然后sub Vac @ say15kHz会显示说-6dB对我有效Robin 以上来自于谷歌翻译 以下为原文 Hi A Are you using the "math" function? That will take you to dBm on Vac set up the null at say 50Hz using measure ref val then sub Vac @ say15kHz will show say -6dB works for me Robin |
khsahdwu 发表于 2018-11-5 13:15 嗨罗宾,是的我正在使用数学函数来测量dBm。 当您测量@ 50 Hz时,正如您所说,并减去您测量的值@ 15 Khz,不使用该仪器,是否仍然是-6dB的差异? 例如@ 50 Hz = + 10dBm @ 15 KHz = + 4dBm差6dBm Arnold。 以上来自于谷歌翻译 以下为原文 Hi Robin, Yes I am using the math function to measure dBm. When you measure @ 50 Hz, as you said, and subtract the value you measure @ 15 Khz, NOT using the instrument for that, is that still a difference of -6dB? eg @ 50 Hz = +10dBm @ 15 KHz = +4dBm difference 6dBm Arnold. |
+ >>但是仪表在-100 dB附近显示非常波动的值!+ Null获取当前的AC读数并从显示的ACV值中减去它。
将转换为dB的无效测量结果给出了您已经看到的接近本底噪声值。 在您的参考值(滚动前)使用测量参考值将dB参考设置为0 dB。 当您的信号根据威廉希尔官方网站 特性下降时,该值将落入负dB读数。 请参阅第58页的34461A手册。编辑者:tayezisk于2014年10月4日上午10:37早些时候的帖子被截断,只留下原来的第一行。 以上来自于谷歌翻译 以下为原文 +>>but the meter shows a very fluctuating value around -100 dB!+ Null takes the present AC reading and subtracts it from the displayed ACV value. The resulting nulled measurement converted to dB gives the near noise floor dB values that you have been seeing. At your reference value (before rolling off) use Measure Ref Value to set your dB reference to 0 dB. As your signal falls off according to your circuit characteristics, the value will fall into negative dB readings. See the 34461A manual at page 58. Edited by: tayezisk on Oct 4, 2014 10:37 AM Earlier post somehow was truncated, only the original first line remained. |
1333 浏览 0 评论
2397 浏览 1 评论
2216 浏览 1 评论
2086 浏览 5 评论
2974 浏览 3 评论
1232浏览 1评论
782浏览 0评论
1030浏览 0评论
1333浏览 0评论
GMT+8, 2025-1-13 11:01 , Processed in 1.562689 second(s), Total 85, Slave 69 queries .
