电子发烧友william hill官网
@ quincyq2003,
对于V6,您需要支持FPGA编辑器的ISE。 您可以查看随附的用户指南。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 fpedit.pdf 2106 KB 以上来自于谷歌翻译 以下为原文 @quincyq2003, For V6 you need to ISE which supports FPGA Editor. You can check the attached user guide. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
@ quincyq2003,
对于V6,您需要支持FPGA编辑器的ISE。 您可以查看随附的用户指南。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- fpedit.pdf 2106 KB 以上来自于谷歌翻译 以下为原文 @quincyq2003, For V6 you need to ISE which supports FPGA Editor. You can check the attached user guide. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
2513 浏览 7 评论
2881 浏览 4 评论
2338 浏览 9 评论
3431 浏览 0 评论
2519 浏览 15 评论
2649浏览 1评论
673浏览 1评论
537浏览 1评论
823浏览 0评论
GMT+8, 2025-3-8 12:10 , Processed in 2.239914 second(s), Total 80, Slave 64 queries .
