你好,
我需要每天早上6点醒来我的NUC7I3BNK。 法国时间。 所以我修改了BIOS以设置时间并保存。 由于我们在法国,夏令时,重启的时间少于2小时,例如,如果我设置在上午11点10分,在重启时我有9点10分。 因此,对于醒来,我设置凌晨4点,一切都很好,我的NUC每天在法国时间早上6点自动启动。 但是,在法国,时间将在今年10月28日发生变化。 这将是冬天的时候,我们将减少一个小时而不是两个小时。 所以这是我的问题:NUC7I3BNK BIOS会自动更改吗? 或者我是否必须再次配置时间和唤醒时间? 如果我必须再次配置,有没有办法这样做而无需进入BIOS? 即使我不在NUC附近,我也能做出改变? 感谢您的阅读,希望您能够回答。 以上来自于谷歌翻译 以下为原文 Hello, I need to wake up my NUC7I3BNK every day at 6h00 am. French time. So i modified the bios to set time and save. As we are in France, Summer time, the time at restart is 2 hour less, for example if i set 11h10 am, at restart i have 9h10 am. So for the wake up, i set 4h00 am and everything is fine, my NUC start automaticaly every day at 6h00 am french time. But, in france the time will change on October 28 this year. It'll be winter time and we'll be one hour less instead of two. So here is my question : Will the change be automatic on the NUC7I3BNK BIOS ? Or do i have to configure again time and wake up time ? And if i have to configure again, is there a way to do so without entering the BIOS ? So i can make the change even if i'm not near the NUC ? Thanks for reading me, hope you'll be able to answer. |
HelloJulien_123,
感谢您加入英特尔®NUC社区。 您需要配置时间和唤醒时间,因为它只是CR2032电池的时钟功率; 它不承认季节和它们各自的小时变化。 配置它的唯一方法是进入BIOS。 如果您有更多问题,请告诉我们。 问候, 艾米C. 以上来自于谷歌翻译 以下为原文 Hello Julien_123, Thank you for joining the Intel® NUC Community. You will need to configure the time and wake up time since it's just a clock power by a CR2032 battery; it does not recognize seasons and their respective hour changes. The only way to configure it is entering the BIOS. If you have more questions, please let us know. Regards, Amy C. |
538浏览 0评论
GMT+8, 2025-1-14 10:59 , Processed in 0.619463 second(s), Total 75, Slave 59 queries .
