电子发烧友william hill官网
大家好,
我有一个关于RAM频率的问题可以与i9-7900x一起使用 在intel ark网站上,我看到RAM型DDR4-2666 Mhz。 我期待一个好的MB tu run,我认为华硕prime x299 Deluxe是一个不错的选择。 但Assus支持RAM直到4133 MHz ...... 我真的可以使用这个频率(没有超频)CPU吗? 非常感谢您的帮助! 艾伦D. 以上来自于谷歌翻译 以下为原文 Hi all, I have a question about RAM frequency can be used with i9-7900x On intel ark site, i see RAM type DDR4-2666 Mhz. I'm lookin to by a good MB tu run and i think the Asus prime x299 Deluxe is a good choice for it. But Assus support RAM until 4133 MHz... Can I really use this freq (without overclocking) the CPU ? Many thank in advance for your help ! Allan D. |
您好adg-bxl,感谢您加入此英特尔社区。我们了解您希望了解有关英特尔®酷睿™i9-7900X X系列处理器内存规格的信息。
我想帮助您。为确保系统稳定性和处理器的长期可靠性,推荐的内存为DDR4-2666。 尽管更高的内存速度可能会起作用,但这仅限于主板支持的最大数量。 现在,可以最大化内存性能,但这在技术上是一种超频形式。 除非您正确配置系统,否则无法实现更高的速度。 如果你想获得更快的记忆,请确保你获得尽可能多的信息。我希望你能发现这些信息有用.Wanner G 以上来自于谷歌翻译 以下为原文 Hello adg-bxl, Thank you for joining this Intel Community. I understand that you would like have some information about the Memory Specifications for your Intel® Core™ i9-7900X X-series Processor. I would like to assist you. To ensure system stability and long-term reliability of your processor, the recommended memory is DDR4-2666. Although it is possible that higher memory speeds will work, that is limited to the maximum amount supported by the motherboard. Now, maximizing memory performance is possible but that is technically a form of overclocking. Unless you configure your system properly, you will not achieve higher speeds. Make sure you get as much information as you can about this if you want to get faster memory. I hope you find this information helpful. Wanner G |
jerry1978 发表于 2018-12-3 17:37 嗨,万纳, 谢谢您的回答。 这证实了我的想法...所以现在我确定;-) 最好的祝福 以上来自于谷歌翻译 以下为原文 Hi Wanner, Thank you for your answer. That confirm what i think… so now i'm sure ;-) Best Regards |
521浏览 0评论
GMT+8, 2024-12-28 00:56 , Processed in 0.579448 second(s), Total 78, Slave 62 queries .
