扫一扫,分享给好友
当我尝试打开一个保存的工作区或尝试启动一个新的工作区时,PSoC创建者关闭。出现的唯一消息是“PSoCuleCalto.EXE已停止工作”,然后程序关闭。我正在研究一个虚拟机Windows 10操作系统。主机操作系统是Mac OS X-EL CAPATAN101.6。我已经尝试卸载和安装程序,但这并没有解决这个问题。
以上来自于百度翻译 以下为原文 Psoc creator closes when ever I try to open a saved workspace or try to start a new one. The only message that shows up is "Psoc_creator.exe has stopped working" and then the program closes. I am working on a Virtual machine windows 10 operating system. The host operating system is mac os x El Capitan 10.11.6. I have already tried to uninstall and install the program but that did not solve the problem. |
我们测试了使用PSoC软件和工具包上的虚拟机软件并行的MAC操作系统。测试和支持以下配置:
G.Mac OS X-EL Cabpon在VMware融合8运行Windows 8.1 Mac OS X-EL CabPon并行桌面11运行Windows 10 以上来自于百度翻译 以下为原文 We test the Mac operating systems using the PSoC software and kits on the virtual machine software Parallels. The following configurations are tested and supported: >Mac OS X El Capitan on VMware Fusion 8 running Windows 8.1 >Mac OS X El Capitan on Parallels Desktop 11 running Windows 10 |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
576浏览 2评论
430浏览 2评论
440浏览 2评论
390浏览 2评论
951浏览 2评论
GMT+8, 2024-12-28 10:34 , Processed in 1.062178 second(s), Total 76, Slave 60 queries .
