嗨,
我用vivado 2015.3来生成一个sram, 它有以下信息: [common 17-348]无法获得功能“实施”和/或“xc7v2000t”的许可 附上我们的许可证文件& 信佛 xinfo.txt 57 KB Xilinx.lic 2 KB 以上来自于谷歌翻译 以下为原文 Hi, I used vivado 2015.3 to generate a sram, it have the information below: [common 17-348] Failed to get the license for feature 'Implementation' and/or 'xc7v2000t' Attach our license file & xinfo xinfo.txt 57 KB Xilinx.lic 2 KB |
6个回答
你好@ samtu_socle,
您附加的许可证是基于证书的浮动许可证(.lic文件)。 您不能将Vivado与此许可证一起使用。 您需要生成并安装基于激活的许可证(.xml文件)才能使用Vivado。 要知道下面的流程检查链接 http://www.xilinx.com/tools/faq.htm 此视频也很有帮助 http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm http://www.xilinx.com/training/vivado/vivado-activation-floating-license-generation.htm 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @samtu_socle, The license which you have attached is certificate based floating license (.lic file). You cannot use Vivado with this license. You need to generate and install activation based license (.xml file) in order to use Vivado. To know the process check below link http://www.xilinx.com/tools/faq.htm This video can also be helpful http://www.xilinx.com/training/vivado/vivado-licensing-and-activation-overview.htm http://www.xilinx.com/training/vivado/vivado-activation-floating-license-generation.htm Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨Ashishd,
在生成基于激活的许可证之前,是否需要解决可信存储警告? 以上来自于谷歌翻译 以下为原文 Hi Ashishd, Do I need to solve the trusted storage warning before generate activation based license? |
嗨Ashishd,
我们的vivado许可证是浮动的, 我用VLM无法选择。 如何使用“激活浮动许可证”? 以上来自于谷歌翻译 以下为原文 Hi Ashishd, Our vivado license is floating, I used VLM can't select. How to use "activate floating license"? |
喜@ samtu_socle
对于floatinglicense你应该去命令行流。 请查看下面AR的详细步骤。 http://www.xilinx.com/support/answers/60522.html 以上来自于谷歌翻译 以下为原文 hi @samtu_socle For floatinglicense you should go thorugh command line flow. Please check this below AR which ahs detailed steps. http://www.xilinx.com/support/answers/60522.html |
嗨Ashishd,
我们的许可证服务器是Sun OS。 如何申请将我们的激活许可证替换为基于cerfificate的等价物? 以上来自于谷歌翻译 以下为原文 Hi Ashishd, Our license server is Sun OS. How to request that our activation license be replaced with cerfificate-based equivalents? |
你好@ samtu_socle,
您可以在以下网址打开服务请求:http://www.xilinx.com/support/service-portal.html 请查看此ARhttp://www.xilinx.com/support/answers/64535.html 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @samtu_socle, You can open service request here http://www.xilinx.com/support/service-portal.html Check this AR http://www.xilinx.com/support/answers/64535.html Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2479 浏览 15 评论
1511浏览 1评论
603浏览 1评论
468浏览 1评论
2019浏览 0评论
743浏览 0评论
GMT+8, 2025-1-3 04:59 , Processed in 1.351107 second(s), Total 88, Slave 71 queries .
