您好,我最近为Vivado生成了30天的eval许可证。
我使用Ubuntu Linux机箱的MAC地址作为请求,并使用Vivado License Manager的“加载许可证”按钮进行安装。 主要以太网接口的MAC地址(如ifconfig中所示)与许可证文件中列出的MAC地址匹配。 当我尝试综合设计时,仍然说它无法获得合成许可。 Vivado许可证管理器将该许可证的主机ID匹配显示为“否”。 我出错的任何想法? 皮特 以上来自于谷歌翻译 以下为原文 Hello, I recently generated a 30 day eval license for Vivado. I used the MAC address of an Ubuntu Linux box for the request and installed it using "Load License" button of Vivado License Manager. The MAC address of the primary Ethernet interface, as shown in ifconfig, matches the MAC address listed in the license file. Still when I try to synthesize a design is says that it cannot get a license for synthesis. The Vivado License Manager shows the Host ID Match as "no" for that license. Any ideas where I went wrong? Pete |
9个回答
@pedro_uno,
请参阅此AR以将NIC卡命名约定从emx更改为ethx,因为Flexlm工具仅识别ethx:http://www.xilinx.com/support/answers/60510.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @pedro_uno, Refer this AR to change the NIC card naming convention from emx to ethx as Flexlm tools only recognize ethx: http://www.xilinx.com/support/answers/60510.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).View solution in original post |
我应该提一下,我的盒子位于防火墙后面,可以控制对某些网站的访问。
这可能是问题吗? 皮特 以上来自于谷歌翻译 以下为原文 I should mention that my box is behind a firewall that controls access to some internet sites. Could that be the problem? Pete |
请查看以下链接:http://www.xilinx.com/support/answers/42398.htmlhttp://www.xilinx.com/support/answers/56505.htmlhttp://www.xilinx.com/tools/faq.htm
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check these links http://www.xilinx.com/support/answers/42398.html http://www.xilinx.com/support/answers/56505.html http://www.xilinx.com/tools/faq.htmThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
@pedro_uno,
您是否可以在tcl控制台中发布通过运行此命令生成的许可证和env.txt: report_environment -file env.txt 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @pedro_uno, Can you post your license and env.txt generated by running this command in tcl console: report_environment -file env.txt Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
我找不到任何名为report_environment的命令,但我猜你想要我的环境变量。
我发布了“env> env.txt”(已消毒)的输出 env.txt 3 KB 以上来自于谷歌翻译 以下为原文 I cannot find any command called report_environment but I am guessing you want my environment variables. I post the output from "env > env.txt" (sanitized) env.txt 3 KB |
@pedro_uno,
打开Vivado,在tcl控制台中运行此命令:report_environment -file env2.txt 另外,在此处发布您的许可证文件。 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @pedro_uno, Open Vivado, and run this command in tcl console: report_environment -file env2.txt Also, post your license file here. Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
@pedro_uno,
请参阅此AR以将NIC卡命名约定从emx更改为ethx,因为Flexlm工具仅识别ethx:http://www.xilinx.com/support/answers/60510.html 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 @pedro_uno, Refer this AR to change the NIC card naming convention from emx to ethx as Flexlm tools only recognize ethx: http://www.xilinx.com/support/answers/60510.html Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
对于Ubuntu 16.04,我在Askbuntu上找到了这些说明。
现在合成运行。 谢谢 编辑/ etc / default / grub更改行 GRUB_CMDLINE_LINUX = “” 至 GRUB_CMDLINE_LINUX =“net.ifnames = 0 biosdevname = 0” 最后以root身份运行: $ sudo update-grub 并重新启动您的系统。 $ sudo reboot 以上来自于谷歌翻译 以下为原文 For Ubuntu 16.04 I found these instructions on Askbuntu. Now synthesis runs. Thanks Edit your /etc/default/grub changing the line from GRUB_CMDLINE_LINUX="" to GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0" and, finally run as root: $ sudo update-grub and reboot your system. $ sudo reboot |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2479 浏览 15 评论
1510浏览 1评论
603浏览 1评论
468浏览 1评论
2019浏览 0评论
743浏览 0评论
GMT+8, 2025-1-3 04:29 , Processed in 1.512516 second(s), Total 92, Slave 76 queries .
